Results 1 to 10 of 11
Thread: Need to switch inputs when connecting 3.5mm jack
    Jan 2009
    From an electrical standpoint I could do this no problem, but it's not appropriate for audio of course.
    Hopefully someone has a somewhat inexpensive solution for me.
    I don't have surrond this is for audio only and doesn't have to be absolutely perfect.
    So that said here we go:
    I have an aux in on my car stereo, 2 rca jacks (L/R) and right now I have something attached to it.
    I'm going to mount a 3.5mm jack somewhere in my truck so I can plug my phone or some random device into it.
    How can I cut off the existing device when I connect that 3.5mm jack?
    So when the 3.5mm jack is disconnected the existing "device 1" is connected to the aux jack.
    When 3.5mm jack in connected "device 1" is disconnected and the 3.5mm device is connected to aux.
    Thanks,
    Kenny
    Jan 2008
    how complex do you want?
    the easy solution is to use a manual switch with a dpdt relay-- combine the grounds for all the devices, and switch the left/right audio signals..
    otherwise, i used a amp box that had this a long time ago(it was a Niles Audio amp):
    look for a VOX circuit-- or a voice-activated relay:
    http://www.epanorama.net/phpBB3/view...st=0&sk=t&sd=a
    http://www.hobbytron.com/pdf/Vs1E.pdf
    Jan 2009
    I was hoping to keep away from a physical switch but hey lol
    Let me see is my ever shrinking brain has the vox idea straight
    Take a DPDT relay
    common goes into stereo
    "device 1" L & R goes onto the NC ports.
    3.5mm goes into NO ports
    VOX-
    3.5mm L/R ALSO goes into mic port
    12V+ on one side of the vox, relay coil on the other.
    So when audio is picked up on the 3.5mm it activates the vox sending 12V to the relays coil?
    Jan 2008
    thats the way i understand it.
    Jan 2009
    hmm actually no, I think a single channel would go to the vox, it's layed out for a mic signal/gnd the same as a single rca jack.
    one channel passing through the relay one not, might sound wierd but oh well I'll find out lol
    Thanks for the help oh great master *bow* :-p lol
    ---------- Post added at 08:44 PM ---------- Previous post was at 08:35 PM ----------
    Here we go even has a spot for my relay
    http://www.rainbowkits.com/kits/vox-1p.html
    Jan 2008
    whoops-- yeah, so you would need 2 of those kits for a stereo signal..
    Jan 2009
    Well did a little more research thanks to your idea.
    If the switch in the jack does what it's supposed to do, should kick on the relay as soon as something is plugged in
    http://search.digikey.com/scripts/Dk...06837538115191
    Raw Wave
    Nov 2009
    Yeah - most 3.5mm jacks have a switch (usually to the ground/shield) which opens when the plug is inserted.
    Jan 2009
    just hope the 12v doesn't hit my phone lol
    Jan 2008
    uh, the links say that the product is not found..
    is this the product # your talking about?
    CP-3524SJCT-ND
    according to the datasheet(link)
    the switch uses one of the positive leads of the connector--maybe oldspark has some ideas on correctly isolating the power/voltages?
  1. Custom Phono Jack with DPST Switch
    By Red_Beard in forum General Hardware Discussion
    Last Post: 09-10-2007, 03:46 AM
  2. Factory A/C switch + relay= inverter power switch
    By CTcarPC in forum Power Supplies
    Last Post: 02-10-2007, 04:02 PM
  3. 629 lilliput auto switch inputs
    By Shaar in forum LCD/Display
    Last Post: 10-21-2005, 10:06 PM
  4. high level inputs and low level inputs, what does it mean?
    By TiTUS in forum General Hardware Discussion
    Last Post: 09-28-2003, 10:51 PM
  5. Connecting wires to switch, dumb electrical question
    By bombboyer in forum General Hardware Discussion
    Last Post: 01-07-2003, 08:13 AM
