this deals with the speaker resistance.
http://www.prestonelectronics.com/audio/Impedance.htm
speakers use a round coil of wire-- called a voice coil. to create it, a single wire is wrapped around the voice coil part many times.
the amount of times the wire gets wrapped around the voice coil determines how high the resistance is-- the more wire that gets wrapped around, the higher the resistance. the resistance to the power flowing through the wire, is measured in ohm's.
in your case, your amp is capable of 2ohm loads--or, in other terms, a lower resistance then normal.
no amp specs will ever say it, but it is always ok to connect a higher resistance then what is stated in the specs.
to answer your question, the resistance that you connect to the amp is determined by the speakers-- there are no amp settings to change.
but to further explain-- every setup has a advantage and disadvantage--for instance, you have 3 speakers, a 2 ohm speaker, 4 ohm speaker, and 8 ohm speaker.
the 2 ohm speaker will be the loudest, but will sacrifice clarity--you will be able to hear the
music, but it would lack some details.
the 4 ohm speaker will be a little quieter, but will be have a more detailed
sound then the 2 ohm speaker.
the 8 ohm speaker will be even quieter, but will have much more detail then either the 2, or 4 ohm speakers.
to further add to this, each step up in resistance will allow the amp to run cooler-- a 4ohm setup will run cooler then a 2 ohm setup, etc.
as you can see, each speaker setup has a very specific advantages and disadvantages.
and to even further confuse you, connecting speakers in
series/parallel will change the resistance the amp sees.
connecting two 4 ohm speakers in series will have a 8 ohm load at the amp.
parallel will have a 2 ohm load at the amp.
again, each has a advantage-- the 8 ohm layout will boost the sensitivity, and make some sounds a little clearer, but the 2 ohm layout will be much louder, at the cost of clarity.
