Results 1 to 10 of 10
Thread: AMP powering question
    Jan 2010
    Hey All,
    I'm new to the car audio work and have a question about powering my amp.
    I am installing a touchscreen carpc in my dash and then want to run music off the computer and output to the amp which will then send it to my speakers in the car. Since I don't have a head-unit I am not sure how to get the amp working so that it turns off/on with the car. Can I run a remote turn on lead to a different connection in the car such as the lights or other connection that turns on with the car? Or should I put a switch in on the Amp Power cable.
    Any help is appreciated. Thank you!
    Shane
    Jan 2008
    yes, i typically recommend to connect to the acc wire that turned the radio on/off in the radio harness, as that is usually very well documented, and easier to find then other locations.
    May 2008
    Beachwood, NJ
    Quote Originally Posted by shaner3721 View Post
    Hey All,
    Shane
    if you get something like the m2-atx power supply it has the remote amp turn on you can use to power your amp i would use that over a 12v source from the car
    Jan 2008
    depends on your perspective-- if the m2 doesn't power on, neither do the amps..
    and there is also the minor issue where some amps cannot be powered directly off the m2-- it requires a boost circuit using a transistor.
    though the main reason to use the m2 turn on is if you have issues with the pc poping your speakers while the pc boots. connecting to the m2 turn on will delay the amps from turning on for a specific amount of time, designed to bypass the time that the 'pop' would occur.
    for that reason, i recommend trying to wire the amps normally, and then worry about the 'pop' if you have a problem later...
    May 2008
    Beachwood, NJ
    ive used the m2 for over 2 years now with no issue, if your power supply isnt turning on to power your PC then it doesnt matter if your amps turn on my m2 turns on both of my rockford amps fine
    Jan 2008
    yes it does-- i have a aux input the directly feeds my amps for when my carpc doesn't turn on, or someone wants to use a mp3 player in the car-- that way, i don't need the carpc to be on..
    Variable Bitrate djvillar's Avatar
    Sep 2006
    New York, New York
    The DS-ATX is the same way. You need an add-on booster module. But really, there's no need. Just use the 12v rail (yellow) from the power supply. It doesn't fully power on till the computer boots so,.. no pop and its powers off clean too.
    May 2008
    Beachwood, NJ
    anyways my point was to NOT use a 12v source from the car lol
    Sep 2006
    New York, New York
    The 12v in my scenario comes from unit you'd use to power the carpc... How are you going to run an amp or a carpc without using 12v from the car at some point in the carpc setup?
    You going Solar? (kidding).. How do you plan on powering the pc?
    May 2011
    getting 12v to npower in dash pc
    Hey All,
    Shane
    you can use the ignition wires also but, the unit will only power up with the key forward...
  1. Question about powering serious psu
    By Shadowstriker in forum Newbie
    Last Post: 09-04-2007, 02:08 PM
  2. Powering Question ?
    By IntellaWorks in forum Power Supplies
    Last Post: 07-16-2005, 09:51 AM
  3. Powering up MII question.
    By IntellaWorks in forum Hardware Development
    Last Post: 01-28-2005, 09:13 PM
  4. question about powering a usb rom
    By DSM97RS in forum General Hardware Discussion
    Last Post: 04-28-2004, 08:22 AM
  5. powering question
    By siueclipse in forum Power Supplies
    Last Post: 12-11-2003, 05:24 PM
