Originally Posted by
LeonGR
If the amp shut off so easy means that it can not handle the load of 2 Ohms.
Try to connect the subs at series to load with 8 Ohms your amp, that will make the amp deliver more power to the subs before it goes to protect mode and maybe you can have a little of what you wand.
Another thing that i have in mind that some times goes wrong is the polarity between the two subs or between the subs and the other car speakers.
Try to play only with the sub and only with speakers, if you hear that your sub sounds louder without the speakers or that the speaker bass goes down when you bring the sub on then it means that you have a polarity (i think its called face in english) problem. Some times i have see that the polarity between the speakers was wrong and have no bass at all with all front speakers playing together. With 4 x 6" and 2 x 6x9" you must easily make your rear view mirror shake without any sub connected.
If it's difficult to do the test then just try to change the polarity of the sub.
So please double check that you have connect the subs and the speakers polarity correctly (positive with positive and negative with negative).
PS. Sorry about my bad english and sorry if something that i have wrote has been wrote above and didn't see it. :)
