Results 1 to 6 of 6
Thread: // Audi TT Bose replacement //
    Apr 2011
    Hello,
    I have a Bose sound system on my 2002 Audi TT and would like to change the radio consol along with the amp with a unit that supports mp3 / USB / ipod and AUX.
    My question is, if I change the consol and amp and keep the speakers will I lose the sound quality and distribution of my current Bose system? The sound quality will be determined by the new sound system?
    Also, will the bose speakers work well with say an Alpine or Pioneer system or do I have to also change the speakers / sub-woofer?
    Thanks in advance.
    Jan 2008
    you might be better off asking that on a vehicle specific forum that is more familiar with your car.
    Jun 2008
    Perth, Western Australia
    Would you need to change the Bose amp as well, or is it built into the head unit of the car? If you have access to the Bose amp, then check to see what kind of input it takes. If its normal RCA inputs, then keep the Bose amp, and interface the new unit straight into that.
    If its proprietary (It might very well be, I think the Mazda Bose units were all wierd proprietary interfaces), then yes, you might have to remove the amp, but that would definitely be a case of speaking to someone who is more familiar with the car.
    Jan 2008
    i can guarantee that the amp does not have rca-style inputs. but it might accept a low-level input signal, and is capable of running with aftermarket radios/carpc's, but there isn't many here that can help check that..
    Jun 2010
    Vancouver, Washington, United States
    The dash stereo wiring should connect to the amp. If you decide to keep the amp then you would need to get a harness adapter, or cut into your wiring. If you swap the amp, you'll need to tap into the factory speaker wiring anyway. Something to consider.
    Start by finding wiring diagrams and see if Metra makes a harness adapter for your vehicle.
    Apr 2011
    It is not built into the head unit, they are separate. The amp (and the head unit) do not take RCA inputs of any kind.
  1. 2002 audi a4 w/ bose carputer
    By g0t2snowboard10 in forum Show off your project
    Last Post: 11-28-2007, 03:55 PM
  2. 2002 Audi A6 Bose Integration
    By bobbydude78 in forum Car Audio
    Last Post: 11-05-2007, 10:07 PM
  3. Pathfinder Bose Replacement
    By iodine in forum Newbie
    Last Post: 02-25-2007, 12:05 AM
  4. Audi S4 and BOSE wiring
    By prophet in forum Car Audio
    Last Post: 04-17-2004, 06:16 PM
  5. Audi A6 Bose Concert Hu
    By ericdee in forum Newbie
    Last Post: 02-14-2004, 06:03 PM
