Results 1 to 10 of 17
Thread: Carputer with two amps - speaker wiring and tune?
    Oct 2009
    I have my carputer and amps up and running. Powering them is not an issue, I was able to figure that out on my own. however with just a 3.5mm jack, how do I hook up the RCA's from a 4 channel amp (4 speakers) and a mono amp (subwoofer)? Also once it's wired, how would I tune it so it actually sounds good? Am I going to need a USB soundcard or some other device?
    I have a carputer in a mini itx box, it has two RCA plugs up front, but when I connect speakers to them, I get no audio so I have been using the 3.5mm jack (headphone jack). But now that I have two amps, how will this work?
    thanks
    Jan 2008
    just use y-adapters to split the audio to the different amp inputs.
    Constant Bitrate kolton5543's Avatar
    Apr 2011
    Safford Arizona
    Yeah. Just use splitters as long as your ok with just 2 channel audio (Left and Right). But if you want more then you may need a usb sound card (Not recommend) or a expansion slot based sound card only if what your using can't be configured to more channels. Also the RCA ports I believe just plugs into the front panel audio header on your motherboard. If so it may not be plugged in or it is currently configured to not operate. Or it just may not work at all.
    Oct 2009
    yeah I currently have it connected with Y splitters but the the quality of the sound isn't very good. I was thinking like a 4.1 usb sound card. 4 speakers and a sub. What do you guys think?
    May 2010
    Australia
    So are you trying to get fade and balance?
    An onboard card would probably be better again but would be interested to hear how you go with a usb card..
    Dec 2007
    Sydney Australia
    You haven't told us what ITX board you are using.
    You might just have to load the correct audio driver for the on-board chip so that the full features like redirection of microphone and line-in plugs for the extended 5.1 outputs can be done.
    VIA Pico ITX, M2-ATX clone, 7" Seform 800x480 LCD Touchscreen, Dual 2x75WRMS Mini Amps, IDE-CF & SATA-CF adapters, 8GB (Sys) & 32GB (MP3s) CF, ELMscan5USB, Slot-load DVD, Craig Brass DAB+/FM USB module, Odyssey Navigator
    Build 90% Apps 50% Install 10%
    Oct 2009
    I'm not even sure, I bought it used off of craigslist. Sorry I'm a newb when it comes to this, this is the same case that my carpc has:
    Dec 2007
    Sydney Australia
    So are you confident enough atleast to open the case and have a look at the motherboard to see if you can find a part number ?
    Oct 2009
    Yeah I'll take a look when I get home. I remember going through the control panel and it said Realtek HD Audio Sound Card, not sure if that is helpful but I'll pull a part number later today.
    Thanks for the help
    Oct 2009
    Thanks for the help
  1. Utilize factory subwoofer and speaker amps
    By miwise in forum Car Audio
    Last Post: 01-13-2007, 01:29 PM
  2. Speaker wire to ground amps etc?
    By geeky_hawkes in forum Car Audio
    Last Post: 10-08-2006, 06:16 PM
  3. Replies: 8
    Last Post: 02-14-2006, 07:43 PM
  4. Replies: 25
    Last Post: 08-04-2005, 12:49 PM
  5. Can I connect 2 amps to the same speaker
    By kingtut in forum General Hardware Discussion
    Last Post: 07-26-2004, 05:23 AM
