Results 1 to 7 of 7
Thread: Kicker CompVR 12" like new but makes weird sound.
    Jun 2011
    I just recently got a CompVR 12" Kicker 4Ohm DVC - http://www.kicker.com/compvr_aluminized
    hooked up to an Alphasonik PMA300HCA 2-Channel amplifier -
    http://www.sonicelectronix.com/item_...PMA300HCA.html
    I have it hooked up bridged in parallel. (+ to + from amp to speaker and - to - from amp to speaker and connected + to + and - to - on the speakers' other voice coil).
    The problem - the sub makes a crackling/static/feedback noise when played. It doesnt get louder or follow the engine noise it just almost sounds as if the speakers about to go Is there anything anybody can tell from the post I am doing wrong or could somethin else cause this? Need better RCA's or something? I'm just hoping its not the speaker, it appears to be in great shape, still looks new. Thanks
    Jan 2008
    push down in the middle of the cone-- if it scrapes/scratches, then the voice coil is probably separating. this is exactly why i don't like buying used audio equipment...
    Jun 2011
    Well it doesn't make any noise when I push down on it so im not sure. It may just be the sub or maybe feedback or something somewhere. When it hits hard you can't hear it, I don't know if that means anything or not.
    Constant Bitrate kolton5543's Avatar
    Apr 2011
    Safford Arizona
    Does it sound like the sound is actually being produced from the sub or does it sound like something physical like something is actually scraping or rattling?
    Quote Originally Posted by Lincolnman View Post
    Your English is fine, don't apologize. You're doing better than most Americans.
    Jun 2011
    It sounds like it's being produced via feedback or from the amp or something but it seems to be getting worse. I don't understand it.
    Apr 2011
    Safford Arizona
    Then there's a possibility that it could be your amp or you might just be picking up some nasty interference somewhere in the lines.
    Jan 2008
    do you have any other amps installed?
  1. Replies: 5
    Last Post: 07-31-2006, 02:19 AM
  2. Pair 12" Kicker CompVR Subs 800/400 rms $200 dlvd
    By wy3134 in forum Classified Archive
    Last Post: 02-20-2006, 08:48 AM
  3. FS: Kicker CompVr 12"s 800watt/400rms $225 dlvd.
    Last Post: 10-25-2005, 04:33 PM
  4. What a difference USB sound makes!
    By smoothswiss in forum General Hardware Discussion
    Last Post: 08-08-2002, 11:21 PM
  5. Monitor makes high pitch sound...
    By SuperMatty in forum LCD/Display
    Last Post: 03-12-2002, 05:46 PM
