Using long 3.5mm cables instead of long rca cables
So I'm getting ready to finalize the logistics of my setup. I plan on retaining my car's stock amplifier, and so I will be using an amplifier integration harness to do so.
In an effort to keep my wiring clean since I have to run wires to the front of the car as it stands, I was wondering if anyone has used the following setup:
Audio Card -> 2x 12ft 3.5mm audio cable -> 2x 3.5mm/2 rca splitter -> 4x 2ft rca cable ->integration harness
The reason I ask is because: in the future I plan on getting a 4 channel amp, and this setup would allow me to retain the 4 short RCA cables for future use with my audio setup rather than long RCA cables that would be messy.
All input is appreciated
