Results 1 to 3 of 3
Thread: What kind of amp? Speaker set up?
    Newbie NiceLyphe's Avatar
    Jul 2011
    PA
    Im going to be putting in a CarPC and going to be running off of a USB sound card. I was wondering what kind of set up is best and convienent..I was told i could use a 5 channel amp and connect my speakers + sub to it. I was also thinking of just doing seperate amps, A four channel to the Front and Rear speakers, then a seperate amp going just to the subs them self. I do think i want to run about 150-250 watts to each door/rear speaker, but i do not know how much watts i want to run for subs..Guess it depends on the subs i go with..Was looking at some 300Watt or some 500Watt kickers..For example, here is the 300Watt one, I'd Most likely run two of these in a single box. Unless a single one at 300 watts will be good enough, but I dont know.
    http://cgi.ebay.com/KICKER-10C12-4-C...item5ae1aaf4f7
    Below is a diagram I wrote up..Kind of how I can picture all my power running throughout the car. I need to know if this is proper..Stock Alternator is 80AMP, I dont want audio to end up serging the vehicle.
    Main question is, what kind of amp set up is better in this situation, for example, a 4 channel at 1k watts + another amp at 300 watts to support the sub or a 5 channel at 1300 watts or somethng of that sort to support all the speakers at once?
    Jan 2008
    1.personally, i prefer individual amps over all-in-one models. mostly because it is easier to match stuff then to build the system based on the available power from the amp(most 5 ch amps seem to have minimal wattage for subs..)
    though, in a tight install location, a 5ch amp will save precious room.
    2. capacitor.
    other then something else to spend money on, it is useless. caps are good for the first heavy 'bump' of a system(they are used on large motors--like home air conditioners because of the heavy startup power that a/c units require), and after that, they just become a parasitic load on your charging system. in fact, many spl competitors do not run them because they can get higher spl numbers without. though, i am still looking for data to prove that they could increase the sound quality of a system...
    3.invertor.
    they are really not recommended because so many introduce noise into the pc system, and cause even more problems. a dc-dc solution will be much quieter.
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    Jul 2011
    PA
    I can def do a dual amp set up, Space is not limited at the moment, I just want it to look clean. Yea I'm going to upgrade my alternator and should be good from there hopefully, going from 80AMP to 125AMP. Inverter is the only thing i have though of at the moment since the unit is a pre-built unit which is AC. Any ideas on fixing that situation?
  1. Replies: 5
    Last Post: 10-12-2009, 10:36 PM
  2. Kind of off topic, kind of not, "Aximizer"
    By Tidder in forum Off Topic
    Last Post: 03-16-2008, 06:25 PM
  3. Help with 4 speaker stereo in 2 speaker car
    By phillip hatton in forum Car Audio
    Last Post: 05-22-2006, 12:27 PM
  4. Direct Sound from PC...What kind of speaker?
    By Zebelkhan in forum Newbie
    Last Post: 02-11-2005, 04:04 AM
