Hi following on from another thread thought id chuck it up in a more specialiesed section
just installed my 3rd revo in a car, none of which i have access to now but all worked flawlessly, now in my new car i have trouble![]()
The audio output from the machine is poor, if i turn up volume on the machine to max the sound quality is distorted once being fed into the car headunit.
tried using iphone and different laptop both of which play music and good volume not distorted and car works fine.....
have tried using an external sound card and this has the same problem any ideas.....
My 2001 Mitsubishi Eclipse GT:
"The Project That Never Ends"
more projects then time!
Led Skyline Tail Lights--100%
High Power Led Reverse Lights--100%
Led third brake light--100%
Led front turn signals--0%
HID retro--100%
do you have the latest audio drivers?
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
Computer was fully updated Via windows before it went in the car, no option to roll back drivers either....
i ran a fresh feed from the battery for the PC and even made a new ignition feed using a relay from this same new feed taken a trigger feed from the existing ignition circuit
