Results 1 to 10 of 11
Thread: how to power amplified antenna with carpc
    Jul 2011
    Hi everyone,
    I have been looking around for a while to solve this issue but maybe I am not using the right keywords or something.
    I plan to use the Dabby DVB,DAB+, FM USB tuner. I plan to plug this into factory antenna, which is an amplified antenna. I have all the necessary plugs/cables to convert from OEM to RF.
    The question is, can I just hook the antenna power cable to 12v DC or do I need to hook it up to 5v or something?
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    All the car antennas i've seen that need power require 12v DC
    Live mp3Car Facebook Chat
    Raw Wave
    Nov 2009
    Ditto.
    Usually powered from "aux power outs" on radios else the ACC position (or whatever...). Some or most radio antenna (controller) circuits are also suitable - ie, those supply +12V to extend the antenna and later cut the +12V to retract it. (Older ones are often just a pulse to release older "latched" or locked-down manual antennas etc.)
    And AFAIK those amps are usually low Amps. The one I had one (last millennium) was ~10mA; the equivalent of one, or a half, LED.
    Jun 2011
    You need power inserter and a 12v - 5V power supply. Google for konig power inserter.
    Jul 2011
    Quote Originally Posted by Fekker View Post
    This is for a standard antenna, what I am trying to do is use my amplified car antenna, which has a seperate ant power lead. After doing some more research I believe that I can just hook it to the Acc to get it working.
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    FIY, Iím using a powered aerial; the supply of course is for powering the RF preamp located inside the base of the antenna.
    The aftermarket DAB, FM, AM unit I fitted takes 12v to 24v. I connected mine to the ACC line.
    Palm sized ainol MiniPC, 8" Transreflective PRO, Win10, Reverse camera, Dual 10HZ GPS RX's for Speed Display & Sat Nav, FM-DAB & Phone Modules, iDrive interface. T-Screen HVAC control, custom microcontrollers, microcode and FE.
    Jan 2008
    Quote Originally Posted by elpres View Post
    that was exactly what i was going to recommend.
    Variable Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    find the antenna power wire and hook it up to a switch power wire and call it a big fat day
    CarPc
    Project "Driver"
    Planning [99.9%]
    Parts Collected [98.5%]
    Installation & Fabrication [98%]
    Total Completion Level [96.9 %]
    http://www.mp3car.com/vbulletin/work...ct-driver.html
    Jun 2011
    I see, that inserter works for fm/dab as well and is for an antenna without a seperate feed wire like I have, as you now state there is a power wire from the antenna then yes it connects to the acc output from the radio.
    Jul 2011
    right from the start I mentioned antenna power cable
  1. roof mount FM antenna for a carpc?
    By HAVOC in forum General Hardware Discussion
    Last Post: 07-13-2011, 08:16 PM
  2. Has anyone connected their existing antenna to their carpc?
    By sandiegodude in forum General MP3Car Discussion
    Last Post: 02-14-2006, 12:41 PM
  3. UHF/VHF/FM amplified antenna w/DC?
    By xcntrk75 in forum General Hardware Discussion
    Last Post: 02-03-2005, 08:57 AM
  4. Amplified headliner TV antenna
    By ddt in forum General Hardware Discussion
    Last Post: 01-28-2003, 09:26 AM
