Results 1 to 7 of 7
Thread: Amp wiring size & distro block question?
    Sep 2011
    Question Amp wiring size & distro block question?
    Hi,
    I'm attempting to wire my head unit to 2 amps. I have the RCA wiring down, and pretty sure I've got the remote turn on done, my question comes to the actual power wiring.
    I have 2 amps. One Pioneer GM-D9500F and one Pioneer GM-D8500M (monoblock).
    The specs for both amps are as below:
    I want to run a single power cable from the battery (roughly 5 metres/16ft), with an inline fuse about 6-12 inches from the positive terminal, then running through the car into the boot, where it runs into a fused 1 in, 2 out distribution block. The 2 outputs at the distribution block will run into each amp, then each amp will be grounded separately.
    My questions are:
    Judging by the specs, what fuse rating should the inline fuse be?
    What rating should each fuse be from the distribution block (I'm assuming they'll differ)
    and What AWG wire should i use from the battery, then from the distribution block to amps?
    I was thinking considering the 9500F has a 40A fuse in it, and the 8500M 2x30A, then its 100A total, so 100A inline fuse at battery, then a 40A fuse on one part of the distribution block, to the 9500F, and 60A to the other, on a 4 AWG wire?
    Any help is appreciated. Thanks
    Newbie Mr_DJT's Avatar
    Jul 2010
    Bristol, UK
    Check this out for cable rateings
    As for fuses as long as you don't go smaller than what's in the amps and not larger than the cable can handle then you shouldn't have any problems.
    For the main cable from the batt I would consider future upgrades and additions.
    I run 0awg and all I have at the mo is a 300w inverter on a 400 active sub.
    Overkill I know but who knows what I plan to do tomorrow
    Also I would suggest get 1 good ground point then disto block the grounds, but that's just me.
    Hope this helps
    Jan 2008
    ^i agree
    for some reason, i can never view 12volt.com links though... i think my isp is screwy...
    Jul 2010
    Bristol, UK
    Quote Originally Posted by soundman98 View Post
    ^i agree
    Have you tried a VPN?
    Allows me to access American residents only sites and apps.
    Jan 2008
    no i haven't. any further details?
    Maximum Bitrate kegobeer's Avatar
    Nov 2010
    Panama City Beach
    Google for free vpn, and you'll find a few services that you can try. You might also have good luck using a free proxy service, so you can bypass your ISP's proxy and use one that doesn't screw up 12volt.com.
    1999 Mercury Grand Marquis GS with: ASRock E350M1 w/4GB RAM, 80GB Intel SSD, Opus DCX3.120, Visteon HD Radio + HDR-USB, PL-18N wifi, OBDLink Scan Tool, BTA6210 BT, BU-353, Win 7 Ultimate, CF 4.0, Alpine MRP-F240 + MRP-T220, RF Punch 1572s, Kicker 8" Comp.
    Jul 2010
    Bristol, UK
    ^ ditto
  1. why do you need a distro block?
    By craigl33 in forum Newbie
    Last Post: 08-13-2006, 06:15 PM
  2. Newbie Question about Distro Block
    By avix in forum Newbie
    Last Post: 02-22-2006, 12:26 PM
  3. Distro block or no distro block?
    By JeremyM in forum Car Audio
    Last Post: 02-08-2006, 02:40 AM
  4. Distro block
    By Cheekz185 in forum General Hardware Discussion
    Last Post: 01-01-2006, 09:32 PM
  5. For Sale:: PS2 :: Distro block:: Musica RCA's...
    By infintyinf in forum Classified Archive
    Last Post: 06-21-2005, 09:19 PM
