Results 1 to 10 of 12
Thread: Boss 4 Channel Mosfet Bridgeable Car Audio Amplifier help needed
    Sep 2011
    I got a Amplifier a week ago and it is giving me no protection ,no powerlight.
    Just The Boss Logo is having light.Plz i need help.Anybody know what is the problem.
    It happened when i was driving my car and listening song in a hot day and when i checked the amp one fuse was blown.After changing that fuse no power.Before it was ok.
    Constant Bitrate meryan00's Avatar
    Feb 2007
    Indiana
    Does the power line to the battery have a separate fuse? I would check to see.
    Sep 2011
    No bro it does not have a separate fuse.
    Only The fuses which are on amp are there
    Jan 2008
    ^ also check the wires with a volt meter to make sure there is voltage where there's supposed to be.
    Sep 2011
    Yes todat i also checked the wires for the voltages and there is voltage in every wire like battery terminal has 12V Remote Wire has 5V and ground is also good.
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    53
    Unless i'm missing something your remote line should have 12v as well.
    Live mp3Car Facebook Chat
    Jan 2008
    ^yup.
    Sep 2011
    Hafza you need a fuse no further then 12 inches from the battery to protect the wire to the amp
    . If you get a short somewhere in the middle it could start a fire and burn your car to the ground.
    It may not fix your amp but it could save your car.
    Oct 2011
    Sorry to thread jack but I need some Sub help fast. I currently have a Kenwood KDC-X395 HU, with a 1500 watt BOSS Phantom amp pushing 2 12" Kicker Cvr's in a ported box. I just bought 2 15" BOSS Onyx and I am building my own box. These new subs are 4 ohm. If I wire them down to 1 ohm, can i still push them at the same amount of power? My Kickers are rated at 1600 watts max which is what I am pushing them at. The Boss are rated 6k I was going to run them with a 5000 watt Boss Phantom amp. Please help!!
    Jan 2008
    is the amp 1 ohm stable?
    also, you should realise that every time you drop the ohms, you loose some clarity for sheer output. why not just run them at 8 ohms and be done with it?
  1. Boss audio head unit maybe bad
    By Harry Lara in forum Car Audio
    Last Post: 08-13-2011, 10:01 PM
  2. Replies: 0
    Last Post: 02-07-2009, 03:28 PM
  3. G4 digital audio mac and my BOSS CH350 help
    By TCPMeta in forum MacCar
    Last Post: 02-23-2007, 01:19 PM
  4. Fs:alpine Mrp-f240 4/2 Channel Car Audio Amplifier
    By craigt in forum Classified Archive
    Last Post: 07-25-2006, 04:32 AM
  5. 6 channel or 5.1 amplifier?
    By 00christian00 in forum Car Audio
    Last Post: 04-25-2005, 09:55 AM
