Results 1 to 6 of 6
Thread: Volume/Audio control from CarPC to Audio out
    Newbie NiceLyphe's Avatar
    Jul 2011
    PA
    I have a carPC installed in my vehicle,and when i put the volume on the carpc to 1% volume its very very loud, like as if it should be at like 80% volume. Is there a way to get more accurate volume adjustment? I'd like to be able to cycle through volume levels as i normally would in my home, or on an mp3 player for example, but one click on volume + is already really loud.
    My frontend is RR if that helps for any matter.
    Thank you
    Variable Bitrate m2x0p9x's Avatar
    May 2002
    Modesto, CA
    Turn the gain down on your amp a little bit if you use one. I don't use road runner, but in CentraFuse, it uses a few different sliders from the mixer to control volume. Like master, wave, preamp. I have my wave and preamp at 50% because my volume is also pretty loud.
    Jan 2008
    ^i agree.
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    Jul 2011
    PA
    Sounds good, thank you guys, I will check it out.
    Nov 2003
    Connecticut
    that's what i do... i never turn ride runner past like 7%... it's just too loud
    Mar 2006
    Colorado, but Canadian!
    You guys don't have your mixer settings correct.
    In the audio settings slide the wave and media-in lines down lower. Then the master control will have more granularity.
    1.9in x 2.9in -- 47mm x 73mm
  1. Alpine CDA-7949 audio input with volume control
    By STEviltoo in forum General Hardware Discussion
    Last Post: 02-07-2009, 04:17 PM
  2. volume control - audio
    By FireSquirrel in forum Software & Software Development
    Last Post: 08-08-2008, 02:58 PM
  3. M-Audio with ASIO volume control
    By mkysimes2 in forum Road Runner
    Last Post: 04-16-2007, 11:25 PM
  4. How to control audio volume?
    By Outsider787 in forum General Hardware Discussion
    Last Post: 06-16-2006, 10:06 PM
  5. M-Audio Firewire volume control
    By cobra42799 in forum Car Audio
    Last Post: 04-14-2006, 02:44 AM
