That amp is only 4 ohm stable when bridged so you should use a 4 ohm sub capable of 200 watts. I would suggest you look at something like the JL 12W0v3-4 if you want to match to that amp the best. Look at the JL 12W3v3-4 if you want headroom to upgrade the amp later. The trade off is it will be running below it's peak operating range with your current amp.
LinkBack URL
About LinkBacks
