Hey guys, I have 2003 Monte Carlo, in the process of building my car-pc that never took off I did some minor upgrades. I do have the premium sound package, and purchased a Power Akoustik OV2-1600 (Gothic Series) amp, and a FUBR 12". Definitely not great stuff, but the price was right and it did sound pretty good. I bought the sub for an incredible price knowing it had a decent hole in it, was a great deal and well worth it, but the hole has expanded and now it gives out nearly nothing. I would like to upgrade for christmas.
Knowing this isn't that great of an amp I would like to pair it with a reasonable sub, I would love to stick with Power Acoustik but will go elsewhere. I am obviously not looking for that crisp clean sound that costs a premium, I am looking for a reasonable thump.
Any recommendations? The FUBR was great when the hole was minor.
P.S. someone said I could patch it with some rubber cement but never got around to try that, maybe I should this weekend.
I would like to put money into the sound system but I think the car will be traded in before too long so doesn't make sense. The enclosure I have is awesome and so would like to stick to single 12".
Specs of amp below:
PWM Circuitry
Full Selectable Crossover Hi/Full/Low
Three Way Protection Circuit
Tri-Mode Capable
Variable Low Pass 40Hz-120Hz
Variable Hi Pass 150Hz-1.5Khz
18dB Bass Boost @ 40Hz.
310 Watts x 2 @ 4 Ohm RMS
370 Watts x 2 @ 2 Ohm RMS
740 Watts x 1 @ 4 Ohm Mono RMS
1600 Watts x 1 @ 4 Ohm Bridged Max
Frequency Response: 10Hz to 30Khz
S/N Ratio:97 db
THD: 0.02%
2ohm Stable Stereo
High/Low Level inputs With Floating Ground
4 Gauge Power/Ground Connection
