Results 1 to 10 of 12
Thread: Line out is noisy
    Jul 2009
    Squamish, BC
    Line out is noisy
    I have lineout, In and Mic 3.5" connectors from the motherboard. When I connect a set of headphones to the Line-Out I get a lot of hiss. Is there any way to get around this or do I need to abandon that connector and try something else?
    This is the last part of the project. I hope its a quick fix.
    Jan 2008
    what motherboard are you running? are you using a case?
    May 2005
    Rochester, NH
    I would think hiss would be the sound card itself. What happens if you mute it? Is there a mic or line in hooked up? A cheap USB soundcard might be a good investment.
    Jul 2009
    Squamish, BC
    Board is a Quanmax KEEX-2030
    Box is the blackbox-N
    I get the hiss without the engine running. Just switch the ignition to accessories and the system boots but still has the hiss.
    I'm using the onboard sound (realtek 5.1) and starting to think that a USB soundcard is the way to go.
    Jan 2008
    try to ground the negative side of the headphone output to the negative side of the power supply--many of pcb's lack that connection and cause the hiss.
    edit: i should add that most motherboards rely on the case to provide this ground, but because your case is non-conductive plastic, it just can't do it
    Jul 2009
    Squamish, BC
    I will and thank you for that.
    Feb 2012
    hey any luck? having same issue
    Jul 2009
    Squamish, BC
    Quote Originally Posted by bossman137 View Post
    I think so. The power supply failed about 1 hour later. I expect that it was being worked too hard. I now have an M4-ATX instead of an M2-ATX and there is no noise on the line while on the bench.
    Feb 2012
    Ya i have the same one. So what was your fix? I've had the most success with grounding the rca coming from the pc. interference sound is now down to a bearable whisper, but not completely gone
    Jul 2009
    Squamish, BC
    I have switched to a more powerful power supply and I will probably also be switching to a USB audio out box so that I don't need the line-out.
  1. Noisy Opus fan
    By dfk70 in forum Power Supplies
    Last Post: 02-27-2007, 11:13 AM
  2. XO Vision noisy?
    By BREADWINNER in forum LCD/Display
    Last Post: 01-13-2006, 07:25 PM
  3. Noisy Harddrive
    By TheLlama in forum General Hardware Discussion
    Last Post: 10-27-2005, 11:23 AM
  4. Noisy Opus
    By Tha Hombre in forum Power Supplies
    Last Post: 05-09-2004, 05:56 AM
  5. Noisy Signal
    By neli_boy1 in forum General Hardware Discussion
    Last Post: 08-17-2002, 10:53 PM
