Results 1 to 7 of 7
Thread: Review my build idea for me
    kdl
    kdl is offline
    Mar 2012
    Help go over my build idea and tell me if I am missing anything.
    1. acer kav60 netbook with Element 7" Touchscreen Display
    Intel Atom 1.6Ghz - 1G ram - 3 USB - 1 VGA - 1 lousy 3.5mm headphone output
    Attachment 65757
    2.sound processing// two channel USB DAC
    http://www.amazon.com/HRT-Music-Stre...2638516&sr=8-1
    Attachment 65758
    2a. Clarion MCD360 2/3 Way Crossover
    http://www.amazon.com/Clarion-MCD360.../dp/B00069R0LM
    3. stereo amp Rockford Fosgate Punch P400-4
    http://www.crutchfield.com/p_575P400...ch-P400-2.html
    4. Front door components Polk Audio DXi 5250
    http://www.crutchfield.com/p_107DXI5...=5250&skipvs=T
    5. rear speakers staying stock for now
    6. Rockford Fosgate Punch P400-2 - 2-channel car amplifier bridged for 400watt sub output
    7. Pioneer TS-SW2501S4 - Shallow-mount 10" 4-ohm subwoofer
    http://www.crutchfield.com/p_130TSS2...w2501&skipvs=T
    Constant Bitrate besjr69's Avatar
    Feb 2011
    kdl, your build idea is right on point. The use of the USB is a good option, but personally I'd use a dedicated DAC using the optical output of the MB. This will reduce noise trememdously (not talking ground loops, but noises inside the PC like HDD wind up, etc.). I use this setup in my system. Other than that, you appear to have a well balanced design with enough power for all speakers. Seems like a good build to me.
    Bobby
    Variable Bitrate mayhembdm666's Avatar
    Mar 2008
    Adelaide, Australia
    missing the car?
    2004 Holden WL Caprice Auto GENIII
    Base System = Raspberry Pi
    Everything else is pending for now as switched from a Mini-ITX setup
    kdl
    kdl is offline
    Mar 2012
    The car is a mini cooper.
    The PC Does not have any audio optical out. only analog from the 3.5mm jack. so the USB dac is the only real option for me.
    Feb 2011
    Understood. Look out for ground loops. You may have to do some testing to ground the PC and/or DAC properly but it is well worth the headache. I started out using the 5.1 audio out but switched to outboard DAC due to the PC noise. I could never get rid of it. Optionally you can install a ground loop isolator but you may notice a decrease in freq response using one. Anyway good luck to you.
    Sent from my iPhone using Tapatalk
    kdl
    kdl is offline
    Mar 2012
    THanks man. Yea The netbook is holding me back a little bit. The more research I do The less the netbook is working out for me. But when i started this project my inspiration was using the netbook for low power consumption, easy install and quick resume from sleep/hibernate.
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    startup/shutdown for the netbook will likely be your biggest hurdle. Oh, and mounting it in a usable way.
    Former author of LinuxICE, nghost, nobdy.
    Current author of Automotive Message Broker (AMB).
    Works on Tizen IVI. Does not represent anyone or anything but himself.
  1. 2007 VW GTi Build Idea and Questions
    By Ted Graham in forum Newbie - Proposed setup
    Last Post: 04-21-2011, 02:59 PM
  2. Replies: 14
    Last Post: 04-13-2007, 01:23 PM
  3. Hardware Review: Overdue M2ATX review
    By elstev0 in forum The Review Palace
    Last Post: 09-03-2006, 09:10 AM
  4. Hardware Review: Car2PC Alpine MBUS review
    By MatrixPC in forum The Review Palace
    Last Post: 06-02-2006, 06:39 AM
  5. I have an idea on how to build it...
    By sk0tie in forum Power Supplies
    Last Post: 03-11-2003, 11:34 AM
