1 Attachment(s)
CarPC and HD Radio integration question
I'm still in the middle of my build... I just ordered the last pieces for my PC, then I just need to work on integrating the audio into my car.
I'll be bypassing my factory amp and will just go with a 4-channel aftermarket amp... nothing special.
But I also wanted to integrate this http://www.mo-co-so.com/Directed-DMH...cs-dir-hdr.htm so I still have a radio option.
I'm just not 100% sure on how to wire everything up...
Whatever 4-channel amp I choose will obviously have a audio IN, and that should obviously come from the source, which is the carPC, right?
So if I wanted to also integrate the radio receiver I linked above, I can just use an equalizer like this, right?
Attachment 65798
So my audio OUT from my PC will plug into the MAIN IN on the equalizer above, then I can plug the radio receiver into the AUX IN... is this right?
And from what I understand, Centrafuse (which I will be running), can control the receiver (radio stations and whatnot)... but when I select the radio on option from Centrafuse, how will it know to switch to the AUX IN on the equalizer?
