Results 1 to 5 of 5
Thread: suitable amps in a small area to work with?
    Jul 2010
    Finally started doing some of my new build, opting to skip the subwoofers until I stop blowing my fun budget...
    However, I got to thinking I might as well just order them, wire everything at once, and be done with that part of the build. Ok, so I will be ordering some of the 2" shallow mount, 13" power acoustik subs. However, with the box I am building, I realized I have no room for an additional amp for the subs .
    I'm currently running 2 cheap small 500 watt amps for the factory speakers. I'm thinking I should ditch these and look at an amp that can run my factory speakers and the subwoofers. 4 channel right? Or, are these 5 channel? I'm accustomed to home theatre stuff more so I'm not sure the terminology, aplogies.
    Anyways, I've been searching for a while for the smallest amps I can find. Found a mono one that fits my dimensions, but I'm not looking for mono here: http://www.sonicelectronix.com/item_...-PBR300X1.html. Dimensions of my area are about 6.5" width, 3" height, 8" length. Also, not trying to spend alot, as I wasn't planning on this phase yet . Any help, pointers, recommendations would be appreciated.
    Current Worklog: TBA - '05 Rav4 (Mobo Dead).
    www.rav4world.com - Forums for Rav4 owners
    www.flavorfeasts.com - Cooking website/forums
    -Basic forums live atm, come contribute!
    May 2005
    Rochester, NH
    I assume you are running 4 speakers plus planning a sub? How many watts and what type of resistance do you need?
    Unfortunately I think you are going to have a really if not impossible time finding a 5 channel amp to fit in that area.
    Jul 2010
    Yes, 4 speakers and a sub. Here are the specs from the page (I don't know the difference in wiring for ohms):
    13" Single 4 Ohm Shallow-Mount Subwoofer
    Power Handling:
    Peak: 700 watts
    RMS: 350 watts
    I spent a lot of time searching around today but can't find much at all, so I think you might be right that it could well be impossible. I guess Ill just have to keep use one of older mono spares in the meantime. It's not gonna look right at first sitting out, but I guess I'll get used to it. Too bad I won't have any pictures of it until I'm done, so we'll see.
    I'll keep a lookout for an amp, or combination of amps, or something that might be do-able in that area.
    Variable Bitrate heezer7's Avatar
    May 2004
    IL, USA
    Yeah smallest 5 channel I have used/seen is a Apline PDX-5. I actually have one running my midbass and subs. But even it is too big and seems people are asking crazy $ for it now.
    Constant Bitrate kolton5543's Avatar
    Apr 2011
    Safford Arizona
    Well there is this amp that can fit inside of your space with the mono amp you mentioned.
    It is rated for 30watts RMS @ 4ohms x 4 channels. This would be a good addition to the other amp.
    I see a downside to the other amp though. The sub is rated for 350 watts RMS with a 4ohm SVC. The amp can only handle only 75 watts at 4ohms. That isn't very much power for the sub. I'll have a look around and see if can't find anything for you. I'll let you know if I do.
    Quote Originally Posted by Lincolnman View Post
    Your English is fine, don't apologize. You're doing better than most Americans.
  1. Replies: 2
    Last Post: 03-18-2008, 06:36 PM
  2. need fabrication work done Detroit, MI area
    By sunman in forum Fabrication
    Last Post: 08-02-2006, 03:57 PM
  3. FS: Two Small Amps
    By homchz in forum Classified Archive
    Last Post: 07-03-2005, 08:21 PM
  4. Wanted - Fiberglass work in bay area
    By musicthebee in forum Fabrication
    Last Post: 05-01-2004, 10:21 PM
  5. Cleaning my work area!!!
    By tapper1999 in forum Classified Archive
    Last Post: 07-07-2002, 09:01 PM
