Results 1 to 5 of 5
Thread: starting ipad install in f150
    Newbie thenewbreed's Avatar
    Nov 2008
    SE TX
    i will be installing the ipad into my dash in place of my head unit. i will be using a clarion http://www.clarion.com/us/en/product...294767387.html DVC920 as a controller and the http://www.clarion.com/us/en/product...912142973.html DVH940 as the processor. I think I will have to wire an amp to the component speakers in the doors. I use an Audiobahn AA2002T http://www.sonicelectronix.com/item_...hn-A2002T.html as a sub amp for 2 10" Kicker C10's. I actually have another A2002T I would like to use for the R/L door speakers, but I am needing to know if this is possible and how to connect them.
    Nov 2008
    SE TX
    lets word this differently. Can a 2 channel. 2x50 watt amp run 4 JLaudio 6x9's
    Constant Bitrate kolton5543's Avatar
    Apr 2011
    Safford Arizona
    It sure can as long as your 6x9's are 4ohms. This amp requires 4 ohms on each channel to get 50watts.
    Quote Originally Posted by Lincolnman View Post
    Your English is fine, don't apologize. You're doing better than most Americans.
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    For some reason i don't think it's that simple. Depending on how you wire the speakers, the amp is going to see either 2 ohms or 8 ohms (i think).
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
    Apr 2011
    Safford Arizona
    Your right. I had over read the 4 6x9s. I hadn't caught the 4 part of it so I automatically assumed it was 2. Anyways, if you have 4 of them then they will need to be either 2ohm or 8ohm. If they are 2 ohm then wire them as 2 pairs with each pair in series. But I highly doubt that's what they are. If they are 8ohm then wire them as 2 pairs with each pair in parallel.
  1. iPad 2 install in Silverado!
    By torres1708 in forum Apple iPad
    Last Post: 09-20-2014, 11:34 PM
  2. How much would you expect to pay for iPad install
    By buurin in forum Fabrication
    Last Post: 03-30-2011, 09:04 PM
  3. 350z iPad install:)
    By Mesojdm in forum Show off your project
    Last Post: 01-21-2011, 05:55 PM
  4. 2007 STi iPad Install
    By SonicWRX in forum Apple iPad
    Last Post: 11-12-2010, 08:51 PM
  5. Replies: 1
    Last Post: 04-11-2005, 12:29 AM
