Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Fitting an RCA Line level controller
  1. #11
    Jan 2008
    Quote Originally Posted by Sledge1 View Post
    i think the CL-RLC does more than i want it to? line driver = in line AMP?? i just want to attenuate the volume remotely with my stock knob.. correct? (still learning what i need to as i need to..)
    Or would using one of these be better? even though it looks harder to hook up..
    Edit: hrmm JL Audio CL-RLC not available here in Aus anyway..
    Will need to find similar or just try a cheapy.. http://www.jaycar.com.au/productView.asp?ID=AA3078
    all of the above are the exact same thing, just a different outer case/manufacturer.
    the main difference between the above options and the rlc is output volume. if you are currently happy with the output volume of the pc, then the option you linked to before is fine. the disadvantage to it is that you need to loop the audio signal to the knob installation location and back to the amps. regardless of if you run your own cabling, or run rca's, the audio signal goes through the knob, so the loss will be the same with either method. i don't think the loss will be audible, but loss always occurs on longer runs of cabling.
    the main advantage to the rlc is if your setup leaves a little to be desired in output volume, and you also want a external volume control. the biggest disadvantage is the price.
    Quote Originally Posted by slociviccoupe View Post
    is this little device a descent alternative to go from the mini headphone jacks of the pc onboard sound card and output it to an amp? and provide volume control?
    both of the options above are 2 of the many options to go from the carpc to the amp, and include a volume control, and/or tone adjustment. neither is perfect for all situations.
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
  2. #12
    Variable Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    CarPc
    Project "Driver"
    Planning [99.9%]
    Parts Collected [98.5%]
    Installation & Fabrication [98%]
    Total Completion Level [96.9 %]
    http://www.mp3car.com/vbulletin/work...ct-driver.html
  3. #13
    Jan 2008
    ^same thing, different maker.
    HID retro--100%
  4. #14
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    Quote Originally Posted by soundman98 View Post
    btw, i run 4 of the rlc's in my car
    FOUR? Well, I suppose I could step up for the boat.
    1- cockpit mid/high (1 amp, 4 speakers)
    2- cockpit subs (2 amps, 4 speakers)
    3- cuddy mid/high (1 amp, 2 speaksers)
    4- cuddy subs (1 amp 2 speakers)
    actually the cuddy sub amp has a level control, so I guess I'm stuck at 3 until I add the hatch speakers or the stripper pole speakers.
    TruckPC - gutted, being used for test setup
    BoatPC - Update coming this spring
    BlazerPC - PS keeps killing battery
  5. #15
    Jan 2008
    yes, i run a full active setup, so i have 3 for level control for tweets, mids, and subs, and the 4th is for sub level.
    HID retro--100%
  1. HD Radio Line Level - too high?
    By miatacarpc in forum General Hardware Discussion
    Last Post: 06-22-2009, 01:37 PM
  2. Relays for line level audio
    By PaulF in forum Car Audio
    Last Post: 02-18-2009, 04:35 PM
  3. How many get some level of line noise?
    By judoGTI in forum General MP3Car Discussion
    Last Post: 04-01-2008, 11:05 PM
  4. How much line level does the Epia M Audio have?
    By orangewhip in forum Car Audio
    Last Post: 05-20-2005, 07:56 PM
  5. Which Line Level Out To Use On Audigy2?
    By GTPmp3PC in forum General Hardware Discussion
    Last Post: 01-01-2003, 01:49 PM
