Results 1 to 10 of 15
Thread: Fitting an RCA Line level controller
    Jul 2010
    So i've pretty much got everything going in my soarer, and mostly finished**
    See this thread: http://www.mp3car.com/newbie/142492-newbie-here.html
    But i'm wanting to utilize the stock volume knob to control the .. volume
    Rather than try to use a USB to gameport adapter and wire in the knob to that, i'm going to try using one of these: http://www.hifisoundconnection.com/S...id/0/SFV/30046
    My question is.. As the PC in in the boot, and the knob is in the dash, would it be better to run an RCA cable to the front and wire in the controller up there, and then run an RCA cable back to the AMP?
    Or would it be better to leave the controller in the boot near the AMP, and run 3x hookup wires from the volume knob back to the boot?
    Thanks in advance.
    Jan 2008
    that volume control does not have separate modules, so if you want the volume control up front, you need to run 2 pairs of rca's up front.
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    Jul 2010
    the plan is to remove the pot from it and wire in the knob from the front...
    probably should have mentioned that first
    But what do you mean by separate modules?
    Jan 2008
    ah, then your second idea would work.
    by a second module, i mean a controller like the jl audio cl-rlc preamp/volume control-- where the preamp portion is controlled by a remote-mountable knob:
    http://www.crutchfield.com/S-oMnkrs6...io-CL-RLC.html
    HID retro--100%
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    Quote Originally Posted by soundman98 View Post
    I sure wish the cl-rlc wasn't so spendy, I need 3 of them for the boat.
    TruckPC - gutted, being used for test setup
    BoatPC - Update coming this spring
    BlazerPC - PS keeps killing battery
    Jul 2010
    Thank you, but which way would be best to minimize problems and signal degradation etc?
    Jan 2008
    neither. the signal passes through the pot, so your either making your own extensions, or your using premade rca cables to extend it. the signal will have similar degradation from either method.
    by extending the pot, you should be able to keep a smaller wire, which will make it easier to install, but that is about it..
    btw, i run 4 of the rlc's in my car
    HID retro--100%
    Variable Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    CarPc
    Project "Driver"
    Planning [99.9%]
    Parts Collected [98.5%]
    Installation & Fabrication [98%]
    Total Completion Level [96.9 %]
    http://www.mp3car.com/vbulletin/work...ct-driver.html
    Jul 2010
    i think the CL-RLC does more than i want it to? line driver = in line AMP?? i just want to attenuate the volume remotely with my stock knob.. correct? (still learning what i need to as i need to..)
    Or would using one of these be better? even though it looks harder to hook up..
    Edit: hrmm JL Audio CL-RLC not available here in Aus anyway..
    Will need to find similar or just try a cheapy.. http://www.jaycar.com.au/productView.asp?ID=AA3078
    Sep 2008
    is this little device a descent alternative to go from the mini headphone jacks of the pc onboard sound card and output it to an amp? and provide volume control?
  1. HD Radio Line Level - too high?
    By miatacarpc in forum General Hardware Discussion
    Last Post: 06-22-2009, 01:37 PM
  2. Relays for line level audio
    By PaulF in forum Car Audio
    Last Post: 02-18-2009, 04:35 PM
  3. How many get some level of line noise?
    By judoGTI in forum General MP3Car Discussion
    Last Post: 04-01-2008, 11:05 PM
  4. How much line level does the Epia M Audio have?
    By orangewhip in forum Car Audio
    Last Post: 05-20-2005, 07:56 PM
  5. Which Line Level Out To Use On Audigy2?
    By GTPmp3PC in forum General Hardware Discussion
    Last Post: 01-01-2003, 01:49 PM
