2 Attachment(s)
Help wiring up Car Headunit from Scratch, No ISO
Hi
I am looking for some help and was kindly directed to this site as recommended by few members on another forum.
I have a DVD Headunit that came with my car that is fitted but not wired up as previous owner didnt know how to.
Problem is headunit does not have any wiring with it.
I have took a few pictures to show where currently stuck and was wondering if anyone out here able to help match up the 14 pin form the wiring diagram so can start to make an adaptor to fit my car.
The Headunit has no visual make/model etc. I have made an adaptor between the headunit and my cars audio connections using ATX motherboard power upply adaptor and trimmed it to fit, all necessary olour coded wores as per diagram on headunit are done aswell. Just need to know pin allocation so can wire it all up.
http://img51.imageshack.us/img51/959...0820112809.jpg
[img[http://img819.imageshack.us/img819/4356/20120820112832.jpg[/img]
I did open it up to see if any info was printed on PCB and the following is showing
The info below is showing on PCB underneath the top 7 pins reading them from left to right
B+ RL+ FR+ RR+ FL+ ACC ACC
This might help
Any :help:form you is very much appreciated.
Hi
Am looking at using another headunit in car as amp after fitting my dual screens today purely as this has DVD built in unlike my other.
Its a chinese OEM unit and does not have the factory harness. It does however have a wiring diagram on the unit and the unit has a 14 pin connection on back but having trouble allocating wiring diagram to the pins.
I have added some pics of rear of unit and wiring diagram.
I opened up the headunit to see what was on PCB for better understanding and printed on PCB below both rows of pins are from left to right
Still not sure on these are the dont really correspond to wiring diagram if I am reading it right.
Can someone help me out so I can get this wired up, using it as amp between screens and playstation then will replace playstation with android pc once rest of parts arrive.
Attachment 67367Attachment 67368
