Results 1 to 5 of 5
Thread: Help wiring up Car Headunit from Scratch, No ISO
    Aug 2012
    UK
    Lightbulb Help wiring up Car Headunit from Scratch, No ISO
    Hi
    I am looking for some help and was kindly directed to this site as recommended by few members on another forum.
    I have a DVD Headunit that came with my car that is fitted but not wired up as previous owner didnt know how to.
    Problem is headunit does not have any wiring with it.
    I have took a few pictures to show where currently stuck and was wondering if anyone out here able to help match up the 14 pin form the wiring diagram so can start to make an adaptor to fit my car.
    The Headunit has no visual make/model etc. I have made an adaptor between the headunit and my cars audio connections using ATX motherboard power upply adaptor and trimmed it to fit, all necessary olour coded wores as per diagram on headunit are done aswell. Just need to know pin allocation so can wire it all up.
    [img[http://img819.imageshack.us/img819/4356/20120820112832.jpg[/img]
    I did open it up to see if any info was printed on PCB and the following is showing
    The info below is showing on PCB underneath the top 7 pins reading them from left to right
    B+ RL+ FR+ RR+ FL+ ACC ACC
    This might help
    Any form you is very much appreciated.
    Hi
    Am looking at using another headunit in car as amp after fitting my dual screens today purely as this has DVD built in unlike my other.
    Its a chinese OEM unit and does not have the factory harness. It does however have a wiring diagram on the unit and the unit has a 14 pin connection on back but having trouble allocating wiring diagram to the pins.
    I have added some pics of rear of unit and wiring diagram.
    I opened up the headunit to see what was on PCB for better understanding and printed on PCB below both rows of pins are from left to right
    Still not sure on these are the dont really correspond to wiring diagram if I am reading it right.
    Can someone help me out so I can get this wired up, using it as amp between screens and playstation then will replace playstation with android pc once rest of parts arrive.
Size:  26.3 KBName:  20120820112832.jpg
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Where's that thing from - CHINA? It don't follow any "standard" wiring that i can recognize. I would say buy another one then experiment with that one and if you blow it up - oh well! Not much help but you are going to spend a bunch-a time trying to figure that out instead of enjoying another one that is clearly marked and you can install right away.
    IMO!
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8 / Garmin
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
    Jan 2008
    is there a issue with cost of a replacement that you would prefer to try to get this one working over purchasing a new unit? just trying to understand the premise-- personally, i would toss a new generic $30-50 cd deck in the car and call it a day.
    there is also the possibility that the deck is burned up, and they disconnected it to just keep the hole in the dash from making the car look poor-- i'd sure hate to see anyone put a ton of work figuring it all out only to determine the deck is bad...
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by soundman98 View Post
    there is also the possibility that the deck is burned up, and they disconnected it to just keep the hole in the dash from making the car look poor-- i'd sure hate to see anyone put a tone of work figuring it all out only to determine the deck is bad...
    LOL - i kept looking at that word and knew what it meant (though misspelled) but then i realized I couldn't think of the spelling myself! Had t look it up!
    Sorry, got too much time on my hands.
    M2-ATX Power Supply
    Windows XP SP3
    Jan 2008
    ok, fixed it for you
    HID retro--100%
  1. Wiring xenarc power/reset buttons to new headunit. Relay?
    By biktrash in forum General Hardware Discussion
    Last Post: 02-20-2009, 03:59 PM
  2. Replies: 2
    Last Post: 08-08-2006, 05:22 PM
  3. HELP! Wiring Amp with Factory Headunit
    By lavanemanuel in forum Car Audio
    Last Post: 07-11-2006, 03:54 PM
  4. From Scratch
    By GazzaW in forum Newbie
    Last Post: 03-01-2005, 08:58 PM
Tags for this Thread
