Results 11 to 20 of 23
Like Tree1Likes
Thread: House Speakers In Vehicle
  1. #11
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by soundman98 View Post
    would you happen to have anything to back that up? i guess in theory it could cause issues with uneven thermal loading on a amp, but i can't seem to find any info right away that shows that using a single channel off a multi-channel amp negatively affects the amp, or the audio quality..
    Used to work for Tandy in the UK.
    Have had people come in with blown amps when they have done just that.
    I think it depends on how the amp is wired/designed.
    Some are wired as two totally individual amps per channel, but some seem to be wired together in some way.
  2. #12
    Raw Wave
    Nov 2009
    The next paragraph had been moved from the last line in this reply since the rest was incidental being merely comments on "stress & strain" etc.
    However that was before soundman's last reply. But I think we concur. Besides, some amps can be bridged for higher impedance loads. And those that can't can usually be fitted with bridging kits - eg,signal inverters.
    But back to my original reply....
    That brings me to my only relevant comment in this thread, namely that often domestic speakers are not suited to vehicles for environmental reasons - heat, vibration, etc.
    But subs and their enclosures are probably fine - bass vibration generally being worse than g-forces and bumps - provided they handle the heat, or sunlight if exposed.
    Nice thread. And I'm far from expert on audio.
    In fact a relatively recent learning was that "unconditionally stable" at an Ohmage meant it would handle anything above - eg, a "1 Ohm" amp will handle 2, 4, 8 Ohms etc.
    Yes - it's less power, but supposedly fine. (In theory, power decreases by the resistance ratio, eg 8 Ohms will be 2/8 = 1/4 the power output of a 2 Ohm speaker. I also read that "all good amplifiers" exhibit such behavior - not that I see many car amps that do [maybe varying SMPS voltage?].)
    I must have been working on too many "tuned" amplifiers where the output impedances were matched, eg transmitters and maybe old audio circuits.
    But hence IMO the speaker is seen simply as a resistive load, and hence the higher the resistance, the less the current (and less power).
    But thus one point - there is no added stress or strainn on the amplifier because of a higher resistance load/speaker. There is less current, hence generally longer component life and less heating.
    [ At least this should be easier than my usual alternator related discussions when many often say adding caps (why?) or bigger batteries increases the alternator's strain, but they're not considering the long-term. It's the opposite that is true - bigger batts etc decreases the "strain" - it saves the alternator having to replace the extra 30% of battery inefficiency used whenever it discharges. And the batt supplies the shortfall instead of the alternator - isn't that less strain?
    And as to "strain" - is that appropriate? Is a 1Ω amp strained supplying its spec'd power to a 1Ω load? Is it more strained than on a 2Ω load? For a component POV, IMO yeah, they are more electrically stressed supplying twice the current into the 1Ω load, but to suggest that is bad if that is what the amp is rated and intended to do, but I consider neither a "strain" if strain is a negative term meaning an undesirable state. Different if we were discussing extending life, but we aren't - we are either into rated life & performance, else whatever life given our needs. (Ergo, a 90A alternator outputting 80A instead of 70A is not suffering increased strain.) ]
    Nice too to read again the higher the Ohmage (speaker) the better the sound. I've read so many times in (car audio) forums that "the lower the Ohmage, the better the sound". What - less sensitivity is better? I think they mean power output, ie more power (with more distortion).
    Some will know my views on having the PSU integral to the amplifier. Even worse is the reduction in speaker impedance from the olde norms of 4 to 16 Ohms etc, though I guess fatalities need to be minimised at very high power outputs (above ~1kW per speaker?). Maybe one day I'll have an engine bay PSU sending HV to a remote amp that drives higher Ohmage performance speakers (as in live-gig musician performances - maybe a few Marshalls or Fender bass speakers in the back?).
    And now to implement some executive writing... (LOL - I moved the next to up top.) Oh no - intervening replies!!!
  3. #13
    Aug 2012
    Adelaide
    Just to clarify as it seems to be a little confusion in some of the posts... speakers are NOT seen as a resistive load. They are an inductive load (voice coil is an inductor, not a resistor). The rated impedance of say an 8 ohm speaker is given at a specific frequency of generally 1KHz (from memory). This will vary as the frequency varies which it does with audio!
  4. #14
    Raw Wave
    Nov 2009
    I agree. Just use impedance instead of resistance in my reply, it makes no difference.
    Alas I sometimes get told off for using impedance instead of the less complicated resistance (LOL- by similar people to one that argued that "Watts-RMS" is a misnomer (true, but it's so people know it isn't peak Watts) and proposed "Continuous Power" instead - without definition - and themselves measuring Vrms & Irms, hence no "Watts" involved - they were measuring VA!).
    The impact of a speaker inductance (and capacitance) is shown by their impedance dependance on frequency.
  5. #15
    Variable Bitrate eugenweij's Avatar
    Aug 2010
    Rozenburg, Netherlands
    I agree on the single channel issue , it is possible but you will end up with mono , thats why I recommend using 2 channels, and yes that is not the case for a bridgeable amp.
    and for a more elaborate explanation of ohms click here
    when reading that myself this morning it looks like I may have switched some things around while I typed my previous reply late last night
    View my worklog here
  6. #16
    Raw Wave
    Nov 2009
    That link - adding speakers decreases impedance.
    Don't they consider serial additions?
  7. #17
    Aug 2010
    that link covers parallel, serial connections have a different result, connecting 2 speaker is series results in doubling the independence thats for 2 speakers rated the same , for 2 speakers rated differently I imagine that the calculation becomes a bit more complex
  8. #18
    Raw Wave
    Nov 2009
    I was thinking more of the 4 speaker series-parallel combination that has the same impedance as a single speaker.
    But with different impedance combinations it's the same principle. The parallel being half the original impedance is merely the normal Z1*Z1/(Z1+Z1) = Z1 *Z1/2*Z1 = Z1/2. The Z1 * Z2 /(Z1 + Z2) itself is a special case of the complete rule which - for parallel resistances and inductors - is 1/Z = (1/Z1 + 1/Z2 + 1/Z3 +....), ie the reciprocal of the equivalent impedance equals the sum of the reciprocals of the parallel impedances.
    If series impedances are part of the parallel network, they are summed first - ie, Z = Za + Zb +Zc etc.
    Of course the above is only valid for resistors and inductors since capacitance is the opposite - capacitance increases in parallel and decreases in series.
    As to bridging, that was merely to obtain more power into the higher speaker impedance.
  9. #19
    Aug 2010
    that makes sense ( learning moment here )
  10. #20
    Variable Bitrate daclothe's Avatar
    Dec 2004
    it's also important to note that you don't need house speakers to listen to house music in the car.
  1. Replies: 0
    Last Post: 03-11-2011, 06:10 AM
  2. Replies: 8
    Last Post: 11-19-2007, 12:42 AM
  3. In car and in house?...
    By daem0n in forum Power Supplies
    Last Post: 04-23-2005, 05:24 PM
  4. FP in da house!
    By liquid_smoke in forum FrodoPlayer
    Last Post: 11-28-2004, 07:00 AM
  5. I need to get out of the house
    By deadweasel in forum Off Topic
    Last Post: 06-14-2004, 08:40 PM
