Results 1 to 10 of 10
Thread: Small 12v Amps (50w RMS x2 @ 8ohms)
    Newbie dacomputernerd's Avatar
    Apr 2008
    Hey guys,
    I'm looking for suggestions for a small 12v amp for a project. It needs to push ~50w RMS per channel @ 8ohms. Two channels is enough for my use.
    I'll take 30w-50w RMS if it's the right price. Working on a student budget.
    If they make a bridgeable 15w-25w RMS @ 4ohms amp, that would also do the trick. I'd be willing to run two amps if necessary.
    Weight and size is also a concern, hence why I just don't buy something bigger/more powerful. As is cost, as I'm on a student budget.
    Thanks!
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    Could this be something that you could use? http://store.mp3car.com/TDA7850_Inte..._p/com-140.htm Just a thought SNO
    Variable Bitrate eugenweij's Avatar
    Aug 2010
    Rozenburg, Netherlands
    depending on your location, I can reccomend marquant mca200 for this , it's small, lightweight and has 2x100W peak
    I know its for sale in europe for around 20 euros , not sure about the US.
    View my worklog here
    Apr 2008
    Quote Originally Posted by SNOtwistR View Post
    That looks perfect! (except for cost) What kind of heatsink would I run on it? Can it be bridged to two channel?
    Quote Originally Posted by eugenweij View Post
    I'm in Canada, and I should be able to get it shipped here. Whether it's worth the shipping charge, I'm not sure.
    -Electrical Engineering Student.
    Nov 2009
    Keswick,On Canada
    Sent you a PM SNO
    Dec 2005
    Raleigh, NC
    "You're just about as useless as JPEGs to Helen Keller" - Wierd Al
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Apr 2008
    Is this bridgeable down to two channels? Are those wattage output levels with a 32v supply?
    I think this is a better choice.
    http://www.parts-express.com/pe/show...number=320-303
    Any idea of the power output at 14v? The quoted values are at 32v.
    It should be the same no? The amp will just draw more current at a lower voltage.
    Dec 2005
    Raleigh, NC
    Quote Originally Posted by dacomputernerd View Post
    I am unsure. You may want to check over on diyaudio forums, they'd be more knowledgeable than I.
    Mar 2011
    Ohio
    I would think that at the lower voltage the output power will be reduced. This is not a Switched mode power supply with a feedback loop to keep the output voltage at the desired level. Hence the "switching" Part of Switching mode power supply. An SMPS is basically a switch turning on and off really fast. If there is more load, and the voltage starts to droop, the feedback look kicks in and changes the duty cycle of the switch, to leave it in the on state for longer to bring the voltage back up.
    Amplifiers work by conducting current through an output stage that is essentially a "valve" to the bus supply. If the bus supply is 14V, and the "valve" is fully on, and the speaker is 8 Ohms, the current is 1.75A. Since power in Watts is Current Squared times resistance, then 1.75 x 1.75 x 8=25.5 Watts. If you used a 4 Ohm speaker the power would be 14V/4 Ohms=3.5A. The power in that case is 3.5 x 3.5 x 4 = 49 Watts. Also remember Watts and actual loudness are not a linear relationship. They are logrithmic. A general rule of thumb is 10 times the power for something to sound twice as loud.
    Obviously all these calcs are done using straight DC values at 100% efficiency. There is inductance and capacitance (Reactance) to consider. But these give you the general idea. To get more output, you need to increase the bus voltage. It also needs to be stiffened with some value of capacitance. A power supply is only as good as the instantaneous current it can put out. The caps help to supply these current peaks during musical peaks.
  1. suitable amps in a small area to work with?
    By detlion1643 in forum Car Audio
    Last Post: 05-12-2012, 12:33 AM
  2. WTB - Small, VERY Small Computer
    By ukchris in forum Classified Archive
    Last Post: 02-06-2007, 05:38 PM
  3. FS: Small Form Factor PC, Ultra Small Form Factor Motherboards
    By NiteMax Mark in forum Classified Archive
    Last Post: 01-23-2007, 04:52 AM
  4. FS: Two Small Amps
    By homchz in forum Classified Archive
    Last Post: 07-03-2005, 09:21 PM
  5. Another small computer, not tiny but pretty small.
    By TimW in forum General Hardware Discussion
    Last Post: 04-17-2000, 09:07 PM
