Results 1 to 2 of 2
Thread: Aftermarket headunit radio - which cable can i use on radio antenna ?
    Apr 2009
    At home
    I want to install an aftermarket head unit radio on my BMW E39 touring so i would like to put a new antenna cable cause my old one was removed/cut and cannot be used anymore.
    I would like to know what kind of cable can i use to install a new radio antenna in my touring.
    Can i use a normal coaxial cable like the ones we use at home to watch TV ? I mean its coaxial 50 ohms or what cable is it? Can you give me more info, specs about cables to radio antenna.
    Jul 2011
    i dont believe that you can use a normal coaxial cable. it would not matter anyways because if your are going to put in your own aftermarket antenna in they usually come with a good length of cable with them. here is one that you can use what do mean exactly when you say the old antenna was cut/removed. the e39 antennas have a different connector on them so you have to buy an adapter for it to work with aftermarket radios.
  1. Replies: 3
    Last Post: 05-22-2012, 06:40 PM
  2. Help with '05 Impala aftermarket radio
    By impala05 in forum Newbie
    Last Post: 02-19-2009, 01:54 AM
  3. FS: XM Satellite Radio tuner, antenna and serial cable
    By d31usion in forum Classified Archive
    Last Post: 02-25-2007, 06:55 PM
  4. aftermarket radio, yay or nay?
    By jakl27 in forum Newbie
    Last Post: 11-13-2005, 08:00 PM
  5. Secret radio unit - radio-only headunit
    By Hark in forum Car Audio
    Last Post: 07-13-2005, 06:58 PM
