Results 1 to 9 of 9
Thread: Emergency help sound card
    Dec 2007
    NY
    I have a zotac 1.6g processor, 2g ram. I need opticle out so I got a behringer 202 and creative xfi 5.1. Both are giving me choppy audio, sounds like buffering issues. I used the generic drivers and the manufacturer drivers and got the same results. I got the asio4all to increase the buffer and latency and still get the same problem. I see after the fact that the creative needs a 2.2g processor, but can't find any specs on the behringer. This is crazy that I these soundcards need processors that powerful. Does anybody have any ideas to either get one of these cards to work properly, or suggest a good quality card that has opticle out that's not as power hungry?
    Variable Bitrate eugenweij's Avatar
    Aug 2010
    Rozenburg, Netherlands
    I use a cheap usb soundcard with an optical out , only drawback it has is that when the driver loads yu get a thump , so I set my thump timeout to compensate for it.
    I have dual core 1.7 Ghz and also 2gb ram , my cpu load when RR runs and plays music is about 9%
    Don't know if its sold in the US but I bet there are similar products available
    http://www.sweex.com/en/assortiment/...d-cards/sc016/
    View my worklog here
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Check your sample rate in control panel settings, my PC is out of my truck right now but if I recall, I had to change it to 48000hz from 44100 to work right. It's in the advanced tab.
    Aug 2010
    Thats a good suggestion PhilG , didn't think of that
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    I have the same problem with mine, and traced it to high CPU load causing dropped bits, kind of like dropped frames of music.
    I disabled a bunch of services, and turned off some stuff that checks for java updates and things like that.
    Sent from my SCH-I535 using Tapatalk 2
    Dec 2007
    NY
    Everything is set to 48khz.
    I thought it was the processor load as well, but right now my system is near barebone. I only have 43 processes which I believe is standard, CPU NEVER passes 30%, averaging 22% with music playing, and memory is at 29%. I'll search through the services to see what I can turn off. Any suggestions? Do things have to be disabled or can i just make them manual. Only thing I don't want to interfere with is anything that will affect multimedia and general Internet.
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    My CPU load is always spiking when I start hearing clicks, but it also happens when I drive around the backside of our office buildings, and my WiFi starts discovering lots of networks.
    Just for S&G you might want to try disabling your network adapter and test.
    Dec 2007
    NY
    ok, i disabled a crap load of services as well as the bluetooth and wifi adapter. got it down to 30 running services and cpu load to maxing out at 17% just playing music. i dont think cpu load is the cause of my problems, because when i run a couple programs bringing the load up to 45% im not getting any issues. over the next few days ill leave it as is then turn the wifi back on and see what happens. the services i turned off are as follows:
    (from auto to manual)
    _Network location awareness
    _Offline files
    _Power
    _Print spoil
    _Superfetch
    _Themes
    _Windows event log
    _Windows firewall
    _background intelligent transfer service...delayed start
    _Ike and authip ipsec keying modules
    _ipsec policy agent
    _windows driver foundation user mode driver framework
    _Windows update
    _Windows defender
    (from auto to disabled)
    _Amd external events utility
    _And fuel functionality
    _Desktop windows manager session manager
    _TCL/IP netbios helper
    _windows search
    _IP helper
    _diagnostic policy service
    _distributed link tracking client
    _server
    _base filtering engine
    _dns client
    (from Manual to disable)
    _task scheduler
    _portable device enumerator services
    _ssdp discovery
    Maximum Bitrate Dave One's Avatar
    Mar 2005
    Norfolk UK
    Quote Originally Posted by eugenweij View Post
    Is this a PC setting by any chance?
    Sorry to hijack the thread.....
    I have similar problems with my X-Fi 5.1 surround and have just got hold of an Audigy NX 2 to switch back to .
    Cheers,
    Dave
    Vauxhall Astra SXi Car PC installed.
  1. Ewww sound card + video card on dual pci mini-itx reiser card = audio interference
    By psyclobe in forum Software & Software Development
    Last Post: 01-23-2008, 02:59 AM
  2. Opus 250W - Emergency Sound?
    By CubanAffection in forum Power Supplies
    Last Post: 02-26-2007, 06:54 AM
  3. Replies: 6
    Last Post: 11-11-2006, 01:34 PM
  4. FS/FT: Misc compute rparts (CPU, MB, HD, video card, sound card...)
    By greenman100 in forum Classified Archive
    Last Post: 08-18-2006, 06:34 PM
  5. FM sound coming from tuner card not sound card
    By Ascension in forum Newbie
    Last Post: 07-18-2005, 05:24 AM
