Results 1 to 4 of 4
Thread: Replacing rns-e with nexus 7 in an AUDI S4 B7 (2008)
    Jun 2013
    Hi all,
    I am replacing my rns-e with my nexus 7 tablet. I made the box for it and the power converters, haven't tried them yet cause I am stuck with the sound
    I made a headphone jack to 8pin wire to hook up on the c-block of my harness, where the pin out on the rns-e says line out, I did this because I don't have an a-block(???) so I guessed that's where the Bose amp gets audio from the unit. I hooked the cable in and played music on my nexus 7, but nothing... Reading around I guess I have to turn the amp on, but I haven't found anywhere what pin to hook up and what signal to send, any thoughts??
    Thanks,
    S.
    Oct 2012
    I have exactly the same problem trying to use A4 B7 Bose system with a car computer , replacing concert II radio CD . Any help would be very welcome. Thanks
    Variable Bitrate eugenweij's Avatar
    Aug 2010
    Rozenburg, Netherlands
    the amp gets an on signal from the original radio , you need to figure out what pin it is and put 12V on it
    edit:
    Found something
    http://audiforum.us/threads/bns4-pin...etrofit.13247/
    View my worklog here
    Jun 2013
    Thanks :-) :-) it's d13, that much I knew the voltage I didn't :-) :-)
  1. Nexus 7 (Android) in a 2001 Audi S4
    By djsun in forum Worklogs
    Last Post: 08-24-2013, 05:57 PM
  2. **2008 VW GTI Nexus 7 Tablet install**
    By maresgti12 in forum Show off your project
    Last Post: 10-04-2012, 11:01 PM
  3. Replies: 43
    Last Post: 06-22-2011, 10:18 AM
  4. Replies: 4
    Last Post: 02-23-2011, 11:18 PM
