Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: In-dash amp only
  1. #11
    Jul 2013
    Quote Originally Posted by Jigg007 View Post
    Butt-splice this bad boy (verifyplz)
    http://www.amazon.com/Scosche-GM02B-...stereo+harness
    to this
    http://www.amazon.com/Pyle-PLMRMP3B-...+car+amp+3.5mm
    You could probably stuff this back there with out a problem. 6x3x1.5 inches. Granted it's no where near 200 watts per channel, but probably close to 20 per, putting you at the same level of the factory radio. As a plus the wires come directly out of it, which you can just crimp a plug or butt-splice it to the factory wiring. (as opposed to messing with a bunch of screw downs or solders) Looks like it has a 3.5mm input jack (or a set of stereo rcas) so you don't even need a y cable or adapter.
    Thanks for the recommendation! I installed them and they work great! Here's my summary: http://n00bnerd.blogspot.com/2013/09/step-2-audio.html
    I do note some feedback from the car's electrical system on the line, so do you have a recommendation for a good small filter?
  2. #12
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    for future searches... parts express has a line of good little t-amps. They are made by 'sure' check them out
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  3. #13
    Jul 2013
    Quote Originally Posted by scott_fx View Post
    Thanks! I doubt I'll be needing another amp, but if anyone else wants to use a different one in a similar project, they'll have a resource.
  1. Replies: 4
    Last Post: 01-23-2008, 02:45 PM
  2. screen in-dash or mounted on dash
    By johnnm in forum Newbie
    Last Post: 03-13-2006, 09:33 AM
  3. Clarion in dash tv and JVC in dash dvd/am/fm
    By berdine3 in forum Classified Archive
    Last Post: 10-24-2005, 08:54 PM
  4. In dash or Not in dash that is the question
    By belezeebub in forum Fabrication
    Last Post: 12-10-2004, 05:18 PM
  5. How can i fit my in-dash housing into this dash?
    By Slitha in forum LCD/Display
    Last Post: 08-08-2004, 12:14 AM
