Results 1 to 10 of 13
Thread: In-dash amp only
    Jul 2013
    In-dash amp only
    I'm starting on a project to hook up a Nexus 7, to, among other things, play music in my car. I want to hook up a small amp (in the stereo slot). I would prefer to have it as small as possible. I saw this thread: http://www.mp3car.com/car-audio/1402...n-in-dash.html where this was recommended: http://www.bybyte.com/amp.htm
    I thought that might be what I was looking for, but I have barely any experience in audio, especially car audio, and don't know what exactly I'm looking for. All I want is something that will allow me to plug in the 3.5mm headphone jack into the car, using my existing speakers. I have a 1998 Chevy K1500 pickup, with the standard stereo that looks like this (I'm pulling out the stereo for this):
    Is this what I'm looking for? Any similar items that I'm looking for? How am I going to hook this up (i.e. are there any other cables I'm going to need)?
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    Here is the one I use in my 96 S10 Blazer, very similar to the bybyte, but cheaper, unfortunately also from china so it takes 10 days to get it.
    I have a male to female 3.5 mm Y cable coming out of my DAC headphone plug and 2 regular male to male 3.5 cables to the 2 input plugs.
    http://www.ebay.com/itm/TDA7850-4-Ch...item5657d942c7
    TruckPC - gutted, being used for test setup
    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
    BlazerPC - Nexus 7 with Timur's USBROM
    Jul 2013
    Quote Originally Posted by DaveDog View Post
    Thanks, so how do I hook it up? I couldn't find instructions on anything. Are the 4 screw-down ports on the sides where speaker cables go? They look like speaker connections. And the one on the front is power?
    Mar 2004
    Greenacres, WA
    In that ebay link if you scroll down enough there is a detailed diagram of the connectors.
    Jul 2013
    Could you repost the link? It just takes me to the ebay home page.
    Dec 2010
    Wauconda, Illinois
    Butt-splice this bad boy (verifyplz)
    http://www.amazon.com/Scosche-GM02B-...stereo+harness
    to this
    http://www.amazon.com/Pyle-PLMRMP3B-...+car+amp+3.5mm
    You could probably stuff this back there with out a problem. 6x3x1.5 inches. Granted it's no where near 200 watts per channel, but probably close to 20 per, putting you at the same level of the factory radio. As a plus the wires come directly out of it, which you can just crimp a plug or butt-splice it to the factory wiring. (as opposed to messing with a bunch of screw downs or solders) Looks like it has a 3.5mm input jack (or a set of stereo rcas) so you don't even need a y cable or adapter.
    Jul 2013
    Quote Originally Posted by Jigg007 View Post
    to this
    That amp is 11" long. There's no way that would fit back there.
    Dec 2010
    Wauconda, Illinois
    Quote Originally Posted by iamthesgt View Post
    I just checked the model number on three different websites and see nothing about a 11" dimension (just dumped the model number into a google search). Its all close to that 6x3x1.5. Maybe 11" is one of the dimensions of the shipping container?
    Jul 2013
    Huh. Yeah I see that. Not sure where the 11" is from either. Thanks for the link! I hope that works.
    Jul 2013
    Okay well I ordered those two items, and I'll let you know how it works.
  1. Replies: 4
    Last Post: 01-23-2008, 03:45 PM
  2. screen in-dash or mounted on dash
    By johnnm in forum Newbie
    Last Post: 03-13-2006, 10:33 AM
  3. Clarion in dash tv and JVC in dash dvd/am/fm
    By berdine3 in forum Classified Archive
    Last Post: 10-24-2005, 09:54 PM
  4. In dash or Not in dash that is the question
    By belezeebub in forum Fabrication
    Last Post: 12-10-2004, 06:18 PM
  5. How can i fit my in-dash housing into this dash?
    By Slitha in forum LCD/Display
    Last Post: 08-08-2004, 01:14 AM
