Results 1 to 10 of 13
Thread: Using Android instead of head unit - not getting any sound
    Jul 2013
    My head unit was stolen and I haven't found anything I really want to get, so I tried hooking my Android (Samsung Galaxy SII to my RCA jacks going to my amp. I'm not getting anything.
    This is my amp:
    http://www.crutchfield.com/p_500MRPF...00.html?tp=115
    I ran a 3.5mm out of the headphone jack. I have an adapter - 3.5mm --> RCA.
    From that, I put Y-splitters to split each into 2 channels.
    I then hooked the RCA lines coming from my amp into the splitters.
    I'm wondering if something was damaged when they yanked the unit, or if I have something hooked up wrong into the amp.
    Thank you for your help.
    Newbie lburner's Avatar
    Sep 2005
    delaware
    How are you turning the amp on an off? Looks iight but if your amp is not on your not going to hear anything.. Get a cheap eq...
    Sent from my One using Tapatalk 2
    Jul 2013
    I was a little unsure about that - I assume I need that to turn it on and off.
    Mar 2012
    Just hook the remote turn on lead (normally blue) that was connected to your head unit to ignition switched 12 volts so the amp turns on and off when the car does.
    Jul 2013
    If I understand the wiring right, the blue wire comes in from the trunk, and meets up with my door chime and a blue wire that goes to my ignition.
    Jul 2013
    I thought this posted and was waiting on mod approval, but it seems it did not.
    I have a blue wire coming from the trunk, and hooked up with blue wires going to 1) my chime controller, and 2) my ignition area.
    Mar 2012
    What vehicle is this in? Do you have a motorized or amplified radio antenna? I am assuming that the blue wire from the trunk is the one that is attached to the blue with white stripe wire? It appears to be the same one that follows the rca signal cables but it is hidden by the other wires in the photo. In the photo, it appears that the red wire attached to the pink one is cut. If so.... then splice it in to the blue wire from the trunk. If you have a volt meter, you may want to verify that the red wire has 12 volts when the ignition switch is on.
    Jul 2013
    It's a 2005 Chevy Cavalier. It's not motorized or amplified. I'll check the volt on the red. Can I just run it in with the blue ones? Or actually splice it into the blue one?
    Jul 2013
    I tested the red with my multimeter, and it didn't seem like it's 12V.
    Jul 2013
    Can I cut the blue, and wind together the 2 halves and the red and cap it? Do I unhook my battery?
  1. The Android Head Unit Build - The Quest for Power
    By Sonicxtacy02 in forum Mp3Car Blog Talk
    Last Post: 08-26-2013, 06:20 PM
  2. The Android Head Unit Build - Hardware Overview
    Last Post: 07-26-2013, 02:43 PM
  3. Android as a head unit
    By S_K_U_N_X in forum General Hardware Discussion
    Last Post: 06-17-2013, 12:28 AM
  4. Android head unit... Check it out.
    By X219c in forum CarPC News
    Last Post: 08-16-2012, 05:51 PM
  5. Parrot's New Android Head Unit - CES 2011
    By Jensen2000 in forum Mp3Car Blog Talk
    Last Post: 04-06-2011, 01:05 PM
