Results 1 to 3 of 3
Thread: Security Beeping Issue - Blaupunkt Stereo
    Aug 2013
    Hi there,
    I took the Blaupunkt PF1a stereo out of my car (to use a beach speaker system), and wired it to a 12V battery (using the Permanent Voltage connection, rather than the "Code 12V" connection, does this make a difference?)
    The Stereo turns on and after entering the radio code it plays music, however there is a constant periodic beeping (every 2 secs) which appears to be some sort of security feature perhaps? This means it is currently pretty much useless, would be really grateful for any advice/knowledge on the issue!
    My thoughts:
    - No aerial in the back could be the issue, took out aerial connection from car and connected it again... no change.
    - Speakers could be the issue, changed speakers, beeping still there.
    Thanks in advance!
    Rob
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Not really the forum for this sort of question.
    A CarAudio forum or Blaupunkt specialist forum would probably be your best bet.
    However I may have a suggestion.
    I know my Pioneer HU beeps when I leave the control panel on after turning of the ignition, maybe yours is doing something similar.
    Try wiring the 12v Acc to the 12v+
    Raw Wave
    Nov 2009
    Maybe the12volt can help. That has lots of experienced installers.
  1. Beeping on every touch
    By mark_2328 in forum Input Devices
    Last Post: 07-09-2007, 03:16 PM
  2. beeping Prob, help me....
    By azhar5i in forum General Hardware Discussion
    Last Post: 01-11-2007, 12:37 AM
  3. Blaupunkt 7 649 347 318 car stereo. Aux in?
    By sneachta in forum Car Audio
    Last Post: 08-31-2006, 02:11 PM
  4. Epia-800 Beeping
    By Shortman in forum General Hardware Discussion
    Last Post: 05-18-2005, 03:44 AM
  5. Inverter Beeping
    By masch in forum Power Supplies
    Last Post: 07-06-2002, 08:32 AM
Tags for this Thread
