Results 1 to 10 of 16
Thread: More than 1 source
    Jan 2008
    Wellsboro, Pennsylvania, United States
    More than 1 source
    These might be stupid questions but I am curious.
    1. Has anyone hooked up multiple audio sources in their car to an amp...? LIke 2 different devices with RCA ouput? Dod you use some sort of switch or just do it hook up with spliters?
    2. Has anyone ever chanced across a FM/AM Radio that has RCA outs...I mean that's ALL it does?
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    The visteon and directed hd radios have an rca only output. They do am, fm, and hd radio. I know there is a device in the mp3car store that is supposed to switch 4 different audio inputs into 1 output, but I dont know what front ends it will work with, or if it is manual operation.
    Jan 2008
    I didn't even think about HD radio...I don't know how much of that we get up here...I wonder if they do FM and AM also
    Thanks man
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    Yes HD radio's from visteon or directed do am/fm. It's your best choice for a radio. Here is a site with hd stations in your area, http://www.freqseek.com/PA/Wellsboro...-stations.aspx looks like you have 2 in your town but if your close to other cities near by you get lots of choices. SNO
    Maximum Bitrate camo.b's Avatar
    Nov 2011
    I use the directed hd radio here in australia...works a treat for AM/FM..
    Jan 2008
    Does it uyse its own antenna or the same FM.AM antenna on the car?
    Mar 2011
    Ohio
    Is uses the same antenna as the car. In fact, it has a built in FM modulator. You don't even have to use the RCA's if you don't want to.
    Get Mitch's cable, and one of several front ends will control it (Driveline, RR). There is also a stand-alone app, but that's probably best for testing, not full-time use.
    Jan 2008
    So if you were to pick one which would you get? I want to be able to have FM back but I want something that if something goed wrong with the car-puter I have a radio also. I so far seem to like the Visteon looks wise.
    But am I just paying for a name ?
    Nov 2009
    Keswick,On Canada
    The Visteon and Directed are the same unit just rebranded, so if you like the visteon than you will like the directed unit. Now for having 2 different audio sources is another animal. If only in windows and you want more audio in sources you need Mitch's 4 in 1 box sold on the forum store, if you want to use if carputer is not powered up then you will need this unit which have been discontinued but you should still be able to find one http://www.installer.com/item/displa...php?it=rca-sw2 Good Luck SNO
    Jan 2008
    OK I need a little help. I bought myself a Visteon HDZ300 - Seem to work great. Here is a problem I ran into...NO volume control. There is not manual...and I can't find one online. Any suggestions for this? I am running directly into my amp with it and I don't have remote volume control in the front so unless I can figure out how to control it in the HD unit I am screwed there. Maybe I can get a volume control for the amp.
  1. RR source
    By miguelito in forum Road Runner
    Last Post: 01-30-2008, 09:40 AM
  2. Source for 2.0
    By frodobaggins in forum ME Archive
    Last Post: 06-05-2003, 03:12 AM
  3. Another T6 Source?
    By dug1967 in forum Power Supplies
    Last Post: 06-25-2002, 10:11 PM
  4. LCD C++ SOURCE !!!!!
    By mprover in forum Software & Software Development
    Last Post: 09-24-1999, 12:43 AM
  5. LCD C++ SOURCE !!!!!
