Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Like Tree1Likes
Thread: USB DAC to multiple amplifiers. How do I?
  1. #11
    Variable Bitrate rijndael's Avatar
    Apr 2007
    on Earth
    Thank you everyone for your advice and input. Durwood, glad to see you're still on here as well. The Y splitter i dont believe would work for me in this set up as it will have to half it's signal strength down each pipe and then i would have to amplify a weaker signal which raises the noise floor and allows for more interference in an already noisy environment. If it was a 7-10w signal, I would probably try it.
    As for the OTG-Y cable that redheadedrod mentioned, that's exactly how im going to power the unit. I have the 2013 model, which has some issues when both a USB device is attached and you try to charge it at the same time...even with the custom ElementalX kernel that is supposed to work. If I had purchased the 2012 Nexus 7, it's much more friendly to charging at playing at the same time. I hope that someone makes it as easy as the 2012 version for this.
    Trouble deciding on car speakers? Clicky Clicky
    My Myspace page (view my pics for carputer worklog...needs updated)
    Speakers: DLS Ultimate Iridium 6.3 Link
    Subwoofer: removed
    Amplifier#1 (Front Stage): DLS Ultimate A4
    Amplifier#2 (Sub) removed
  2. #12
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Quote Originally Posted by rijndael View Post
    That is not what happens with a y-splitter and audio signals in this case. An RCA cable has minimal resistance way less that 1 ohm. The output impedance of the DAC and the input impedance of the amp are kilo-ohms, hence no noticeable signal loss. Headphones are a different story, as their impedance is much lower.
  1. Multiple Music Paths across multiple drives
    By durwood in forum Road Runner
    Last Post: 02-04-2012, 05:03 AM
  2. 2 amplifiers installation
    By sillyme136 in forum Car Audio
    Last Post: 12-09-2007, 12:35 AM
  3. RF Amplifiers
    By platinumsteel in forum Wireless Communications
    Last Post: 10-17-2007, 08:56 PM
  4. PCI to amplifiers?
    By haf in forum Car Audio
    Last Post: 05-12-2006, 03:43 PM
  5. Multiple Monitors and Multiple inputs
    By nixneon in forum Newbie
    Last Post: 03-19-2005, 07:30 PM
Tags for this Thread
