Results 1 to 5 of 5
Thread: Multiple RCA Outputs - Carputer + Directed HD Radio
    Mar 2011
    I just got my directed hd radio receiver so now I have two RCA outputs. I would rather not have to switch between the RCA outputs so how is everyone else doing this?
    1. Carputer (mp3 output) - soundcard has phono to rca output
    2. Directed HD radio - rca outputs
    Can I just buy a Y to bridge these two together or will that cause feedback? How does everyone else do it without having to switch inputs each time?
    FLAC SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    I run my Directed HD to line in, XM to mic in and out through my line out on sound card to amp Not sure if this helps SNO
    Mar 2011
    Interesting, thanks i will try that. I just noticed that the directed HD line output is distorting anything that I plug it into. Have you noticed a high voltage output of the directed unit causing distortion?
    Nov 2009
    Keswick,On Canada
    Are you using mitch's cable to control or the factory display unit. I have no distortion, but I have to keep my volume level @ 20% on the line in. SNO
    Maximum Bitrate jmullan99's Avatar
    Feb 2009
    Niagara Falls, Ontario
    Noise might be from ground issues. There is a fix on the forums somewhere to add a ground inside the radio box. You can also try a audio ground isolator (basically RCA wires with a filter in the middle), that and the fix helped me.
    Here is the ground fix.
    I bought this isolator.
    One or the other, or both, should help. Try the various combinations. You can temporarily ground one of the ground/shield on the RCA connections to the black/ground at the power connector to try the mod before making it permanent.
    ZOTAC G43ITX-A-E 2.5ghz Core i3 2GB 160GB SSD
    Win7 Ultimate - OpenMobile - Directed HD - Wifi
    OMMaps + MS GPS Puck - WiFi via LTE Android phone
    2 Zones - Matrix Orbital LCD - Arduino - Build Pics
  1. DAC, multiple outputs?
    By incudie in forum Car Audio
    Last Post: 07-30-2008, 12:44 AM
  2. Carputer Help Multiple Video Outputs
    By SuperEco06 in forum General Hardware Discussion
    Last Post: 04-13-2008, 09:24 AM
  3. Triggering multiple outputs with 1 image
    By rgarjr in forum Fusion Brain
    Last Post: 04-05-2008, 03:55 AM
  4. Multiple audio outputs
    By schnaarf in forum MacCar
    Last Post: 08-04-2006, 07:25 AM
  5. Multiple Sound Outputs
    By djXternal in forum Car Audio
    Last Post: 10-04-2004, 02:58 PM
