Results 1 to 8 of 8
Thread: VW CDC emulator and noice
    Oct 2010
    Greece
    Guys need some help again. Some days ago i received this for sending audio to my vw mcd .
    Now we are coming to the problem . The unit makes a lot of noise and i can hear the car when i press on the throttle.
    So what do you think . Is it a unit's problem or can i solve this without the need of dissembling that ?
    The seller didn't give me any solution instead of that he asked me to perform a visit to a prof service point .
    Vw Sharan 2007 1.9tdi || Exide 100Ah
    Fuzzy 945gme + core duo T2400 + 2gb ddr 667 + pci nvidia 5500 256mb + kingston v300 60gb + hdd 2.5" 100gb 5400 + Sure Gps module
    Primary monitor 8" 800x600 || Secondary monitor 15.4" 1280x800
    Powered by M2 atx
    Sep 2012
    Germany - Munich
    the ebay link don't work for me. i think it's a country depended problem
    item-number?
    Sep 2012
    Germany - Munich
    i would try to add in each positiv audio cable a 0.22F ceramic Cap.
    Oct 2010
    Greece
    here is a google link for the emulator
    You mean that i have to open the box and ad this ceramic capasitor. On the output where it plugs on the mcd , or do the easy way and cut and solder on the cable after the box ?
    Powered by M2 atx
    Sep 2012
    Germany - Munich
    The cable.
    Oct 2010
    Greece
    i added two capacitors but it didn't help a lot. It lowered my main volume a lot and there was still noise. So is there anything else i can do ?
    Powered by M2 atx
    Oct 2010
    Greece
    Guys i am here again looking for some more help. I had the device opened ( second time the first was for the capacitors) and took a look. It seemed strange to me that the audio in in the device was two cables attached on the left and right and the ground from the computer audio out was going on the ground . I remembered that on the do it myself device was going to aground.
    I dont know if you got what i ve said, hope you did.
    So i asked to a greek forum too . if i ll try and connect the ground to aground is it possible the device to be harmed ? Could this be a soluition to my problem with this emulator ?
    edit:
    Powered by M2 atx
    Oct 2010
    Greece
    Guys problem solved . I am very happy. I have switched the ground to aground and now it is working perfect. Very glad. And i am wondering these chinese guys cant even see what they are doing. I mean the device had two grounds one coming from audio out. As i can understand that ground and vcc is for charging small devices like ipod and android phones .
    Now i am thinking into plugging these rx and tx to my com and get some control in winamp through my oem mcd.
    anyway case closed.
    Powered by M2 atx
  1. UBS Power, iPod noice issue
    By kalinga in forum Power Supplies
    Last Post: 01-13-2014, 08:51 AM
  2. High pitch noice
    By Charles1 in forum Car Audio
    Last Post: 07-27-2006, 12:06 AM
  3. Loud noice when turning on CarPC
    By Andreas106rally in forum Car Audio
    Last Post: 11-03-2004, 12:27 PM
  4. noice when using 12V from cig-lighter
    By loscooby in forum Power Supplies
    Last Post: 01-01-2004, 05:06 AM
