Results 1 to 5 of 5
Thread: Car PC Audio Questions
    Sep 2013
    Colchester, Essex, United Kingdom
    Afternoon all.
    I have had a car PC for about a year now and slowly realising my Audio isn't as good as it can be...
    Basically i have 2 amps for speakers and subs...
    1 amp for all 4 speakers and 1 amp for sub...
    they all plug into the green output on the motherboard via Y connectors.
    I believe that im not getting separate Subwoofer and seperate speaker inputs from these. As my mate has the same SUB which is being powered by a normal head unit and sounds 10x better than mine...
    Any suggestions would be amazing thanks in advance.
    Elsewhere
    The Y connectors for your audio signals are part of the problem, methinks.
    You're splitting the signal in half for each line.
    Two possible solutions:
    1. Configure your sound card/chipset to output 5.1 and ignore the center channel. Then use headphone jacks into RCAs for each audio channel.
    2. Put an EQ/preamp between the PC and the amps. Run simple L/R stereo into the EQ/pre-amp and let is split the signals into 4.1.
    I use the second option. It makes for less headaches, especially when you get an MP3 that someone encoded for only 2 channels or something stupid.
    You get the added benefit of higher audio signal voltage feeding the amps, which results in better overall sound quality.
    How about the Wiki?
    May 2010
    Her√°kleion, Iraklion, Greece, Greece
    For starters, i beleave that the motherboard sound card, can never, give you high enough quallity, to make perfect use of the two amplifiers... in my car i use an external USB sound card.
    When you split the signal, you only have left and right channels. but keep in mind that car audio systems, are not designed for "5.1" or similar setups... each car has different speakers in different places.. i beleave that one good solution would be to buy a pre-amp equallizer. give the low pass outpout to the amplifier that drives your woofer, and split the mid and high outpouts, between your front and rear...
    but, i am no expert, and i am pretty sure there can be better solutions... :/
    Elsewhere
    Quote Originally Posted by settra View Post
    Ten years ago, I'd agree with you.
    Currently, I think audio hardware has improved exponentially, to the point that an onboard sound card's quality is as good as any other add-on sound card (internal or external) save for the highest quality audiophile-oriented hardware, which is cost prohibitive to most of us.
    I agree with this. It's the very reason I use a pre-amp/EQ in my setup.
    (AudioControl Three.1 if you're at all interested)
    How about the Wiki?
    May 2012
    Grandville, MI
    Many here also use a USB DAC. Those can be as complicated as you want to get or can afford.
    Especially if your motherboard can handle optic output for your audio.
    Regardless of what you use the PROPER way to do it is as has been mentioned. Send your 2 channels to a sound processor that will do the work for you. As it is you are reducing your output to your devices and you have no cross over so all of your speakers are running full range which is very inefficient.
    A simple USB dac can be had for somewhat cheap but so can a digital crossover that you need.
  1. Few questions about car audio.
    By Chace in forum Car Audio
    Last Post: 06-04-2010, 10:06 PM
  2. two questions about audio!
    By magarious in forum Car Audio
    Last Post: 11-25-2006, 03:51 PM
  3. some audio questions for my setup
    By PatrickB in forum General MP3Car Discussion
    Last Post: 05-11-2005, 08:37 AM
  4. Few questions... Audio/GPS/etc.
    By PCGUY112887 in forum Newbie
    Last Post: 03-11-2005, 05:34 PM
  5. Audio questions
    By contri in forum General Hardware Discussion
    Last Post: 07-24-2003, 07:11 PM
