Results 1 to 5 of 5
Thread: HD audio from Nexus 7 to JL XD700/5 amp
    Jan 2013
    Question HD audio from Nexus 7 to JL XD700/5 amp
    Hello. I am a noob (with car audio) that installing a Nexus 7 into his truck. Can someone please tell me the best way to get great sound to my 5 channel amp? I know that an Audison BitTenD and an Audison Voce amp would be the true audiophile setup, but I'm hoping for a less expensive solution.
    This is the LAST thing that is holding me up from having a completed build. I have a powered hub so charging/DAC output is not an issue. I know there are lots of ways to get the signal from the tablet to the amp, but I'm trying to get the best sound that I can. If I need to add or take away from this setup let me know. Thanks guys.
    Here is a breakdown of my sound system:
    Vehicle: 2009 Dodge Ram Quadcab SLT
    Tablet: 2012 Nexus 7
    DAC: iBasso D-Zero - http://www.ibasso.com/products-detail.php?id=269
    EQ: Sound Storm S4EQ - http://www.soundstormlab.com/auto/ca...nd-storm-s4eq/
    AMP: JL Audio XD700/5 - http://www.jlaudio.ca/xd700-5-car-au...plifiers-98264
    4Door Speaker System: Focal Polyglass 165 V30 - http://www.crutchfield.com/S-uljIr2m...s-165-V30.html
    Subs: 2x JL Audio 10W1v2-4 (Tweeters and both subs run off of single channel) - http://www.jlaudio.ca/10w1v2-4-car-a...-drivers-92072
    May 2012
    Grandville, MI
    You can use the audio out from your tablet but it is only two channel. You would have to feed it to a crossover to get your subwoofer output or use some other sort of processor.
    Your tablet should have bluetooth out and you could use that but would be the less desirable solution.
    Otherwise if you want to go off your USB you can look for just about any USB sound card. The only issue will be if your ROM recognizes your sound. You MAY also be able to find a DAC that will work as well but I have no experience with a DAC and android. A DAC will have built in crossovers and in some cases time alignment stuff but I have not heard of a DAC that works with Android.
    Rodney
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    Everything on your list looks good, but the DAC you show has a headphone amp in it. You can get a high quality DAC for $59 if you get the hifimediy Saber asynchronous model. 117 db snr.
    Sent from my A0001 using Tapatalk
    Jan 2013
    Quote Originally Posted by rray View Post
    I chose one with a built-in amp so that I could pretty much use it as a pre-amp. Is this a bad choice? Also thank you for your reply.
    Jan 2013
    Thread closed.
  1. Transmitting Audio Through Nexus 7
    By AustinMiniMan in forum Android
    Last Post: 07-21-2014, 10:27 AM
  2. Replies: 1
    Last Post: 04-29-2014, 02:54 AM
  3. The Nexus 8 (Mazda RX8 Nexus 7 / Focal install)
    By Framinator in forum Worklogs
    Last Post: 04-04-2014, 12:49 PM
  4. Replies: 23
    Last Post: 12-26-2007, 06:54 AM
  5. RELEASE: iG-Nexus (for iG3 UMPC, CF, Nexus)
    By RPM_VR4 in forum SB Skins
    Last Post: 10-25-2006, 11:53 PM
