Results 1 to 4 of 4
Thread: Checking audio input in bmw e39
    Jun 2015
    Hey guys,
    I just recently started to work on my car-PC project and I tried to check the sound first. So, I've removed OEM radio with business CD unit and plugged-in a simple amplifier (4x50w). I tried to apply ~1.3V DC to the amplifier's audio input using AAA battery expecting to hear some cracking sounds in the speakers, but that didn't happen. I've checked that amplifier's DC input is fine and verified there were some DC on audio output as well. Any ideas what else needs to be done to make this simple schema to work?
    - Pavel.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    The radio may have connected to and amplifier before finally going on to the speakers.
    In which acse turning on the radio may have turned on the amplifier.
    In which case no radio no amplifier.
    The above could be totally wrong though.
    Jun 2015
    Right, the radio actually "controlled" an amplifier and turned it on.
    Basically, I had to connect 12V Ant Out to 12V ACC.
    Sep 2012
    Germany - Munich
    Do you have DSP?
    Is it correct, you connected a battery on audio input? Try to connect an audio source.
  1. Audio input
    By Joshc8503 in forum Car Audio
    Last Post: 03-10-2010, 11:53 AM
  2. Latency Checker for checking audio/video streams
    By WuNgUn in forum Software & Software Development
    Last Post: 11-22-2008, 09:45 AM
  3. Two audio signals, one input.
    By derbis in forum Car Audio
    Last Post: 11-16-2005, 11:45 PM
  4. how to add audio input
    By skycart in forum General Hardware Discussion
    Last Post: 08-07-2005, 10:33 PM
  5. audio input?
    By mr0range in forum General MP3Car Discussion
    Last Post: 11-04-2001, 07:33 AM
Tags for this Thread
