Results 11 to 20 of 21
Thread: Potentially poor sound quality with carputer vs. HU
  1. #11
    Melbourne, Australia
    Yes.
  2. #12
    Maximum Bitrate jusatry's Avatar
    Nov 2003
    search corruption, search
  3. #13
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    Quote Originally Posted by Vineet Singh
    Cool!
    Still wondering though, does anyone have any noticeable computer noise through their internal or onboard soundcards? Phono jacks aren't shielded very well, what are you all doing to get the signal to RCA?
    No noise what so ever through my Audigy 2 ZS card. I use a 1/8 adaptor to RCAs to Stinger RCAs to EQ/Pre Amp to amps. Damn good sound I might add.
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
  4. #14
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    Quote Originally Posted by Defiler
    Same here PCI Audigy sounds fantastic, and its in the case running cheap RCAs all the way to the head unit. No noise.
    Fabricator
  5. #15
    Constant Bitrate c0rrupti0n's Avatar
    Mar 2004
    Miami
    I have searched plenty, forums, google, and and the yellow pages... And have found nothing! Tis why im posting... I dont mean to nag, but its not like my question would take a doctorate to answer...
  6. #16
    Jan 2002
    Temple Terrace, Fl.
    Quote Originally Posted by c0rrupti0n
    Can i get an explanation of how or why I would need to ground my puter? Would i simply screw a small guaged wire to the side of my case running to the chassie of the car (all done in the trunk)?
    Hmm, must have skipped over this by accident.
    I have never grounded any of my puters in the past. Some people say it helps when they have noise but I never had noise so there was never a need to do it.
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
  7. #17
    Maximum Bitrate falconey's Avatar
    Feb 2004
    Atlanta
    Depending on the computer, the car and most importantly the way the set up is installed(wiring, etc.) you may or may not have to ground the case. If you're using a inverter I'd say always ground the case or any other electrical device if using an inverter. Under other circumstances I'd do a test to see if the sound is picking up interference before grounding the case, not that grounding the case would hurt anything.
    Corruption- I can't give you a technical explanation for why you should ground the case, but I've experienced in my test install alty whine. The problem was resolved when I grounded the case. I'm using an inverter and basically I think that because of this the computer was not properly ground. I'm sure there's some type of ground inside the inverter, but for the car environment it may not be the best type of ground. Again just look at it from your needs and if you don't need to do it, don't.
  8. #18
    Aug 2003
    Defiler and Altimat: What do you guys use for converting the cable from your audio out to your amps? Defiler, you mentioned the use of a 1/8 adapter. Can you post a pic of this? All I could find at Rat Shack was this black adapter which had one 1/8 male for the PC and 2 female RCA inputs for the RCAs. It's a solid plastic piece about 1" x 1". Is this what you use??
    Thanks!
  9. #19
    Mar 2004
    Miami
    hey SQ Geek, I just bought 3 of these. There perfect fort he job... http://cgi.ebay.com/ws/eBayISAPI.dll...094067655&rd=1
  10. #20
    Jan 2002
    Temple Terrace, Fl.
    Quote Originally Posted by sq_geek
    Thanks!
    I have what corruption just posted except they are gold plated.
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
