Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: embarrassed to ask: subwoofer wiring?
  1. #11
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    Use the speaker level inputs on the amp if it has them. Otherwise you need to convert the speaker levels to RCA's.
    If your amp has speaker level inputs, you just tap into the rear left or right + and - speaker wire. (Only need one if you run single mono sub)
    If the amp has a built in sub crossover you can trun that on so no high frequencies go to the sub.
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
  2. #12
    Mar 2004
    Los Angles
    LESLIEx317537 don't say something stupid just right or just left is not mono right and left combined is mono if only use one side you will only get half of the sound
  3. #13
    Jan 2002
    Long Island, NY
    What are you talking about?
    I didn't say somthing stupid. Lets look at the facts.
    I have a Kenwood amp that is stereo (2ch) and it says to hook up the left rca to the left rca in on the amp, the right rca is not used for a mono amp setup.
    Bass is not directional. What is int he left channel will be in the right channel. Most people do not make music with bass balance.
    So please, unless you wanna get flamed, don't say I said somehting stupid. I was trying to help and I hate when I see a post like yours above.
    I have a Audigy 2 NX 5.1 digital setup going in my car with 2 amps. Any questions?
  4. #14
    Jan 2002
    Long Island, NY
    #1 rule. n00bs should not say that old school members say stupid things.
    Half the sound is the dumbest thing I heard so far. What's that mean?
    Bass is encoded in both channels fool.
  5. #15
    Variable Bitrate Pokey's Avatar
    Tampa, Florida
    Simple Cross over
    An inductor will pass low frequencies and block high frequencies, a capacitor will pass high frenquency and block low frequency.
  6. #16
    Sep 2009
    So confused
    alright so my plan is hijack my two rear speaker wires from the stock head unit, splice them and send both channels into a line converter then to amp etc. The reason I want to do this is because if I only use one rear channel wont that mean that some songs wont be played out fully in stereo for the subs? Well anyways, If i splice into them and then also attatch the original speaker connections so that the rear stock speakers still play aswell, will that alter voltage, ohms....... anything bad gonna come out of that?? Is it bad to have the rear speaker outputs from the head unit running into a four-way splice?
  1. Please advise... Power wiring
    By boom in forum Power Supplies
    Last Post: 01-29-2004, 07:20 PM
  2. datalux 4x20 red lcd wiring diagram?
    By etrik in forum LCD/Display
    Last Post: 12-07-2001, 04:35 PM
  3. Specific wiring schematic 4 Optrex DMC40457?
    By sooty in forum LCD/Display
    Last Post: 07-17-2001, 03:11 AM
  4. Strange wiring problem .....anyone???
    By edie209 in forum LCD/Display
    Last Post: 06-06-2001, 08:00 AM
