Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Amp Wiring Kit
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    Amp Wiring Kit
    Hey. I recently bought a 400 Watt amp, and wiring kit. Opened the kit up and realized. ..DOH! Wrong wattage... or so they tell me. The kit includes X amount of 8 AWG power wire. Will 8 AWG work with my amp? HMy justification for keeping it is that the fuse the kit comes with is 30 Amps, the same size as the fuse on my amp. Also, it is a crunch, low level which means it's probably over-rated. If I maxed out the wire it came with, it'd max out my amp... which I don't see happening with my conditions. My amp is just powering two 6.5's and two 6*9's. Thanks for your input.
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
    Constant Bitrate TaylorMade's Avatar
    Nov 2003
    Tampa, FL
    what size amp are you running? If you're only running a set of 6.5s and a set of 6x9s, it should be fine. Is it a 2 channel amp or a 4 channel amp? The lower the ohm load, the more power consumption.
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    2 channel amp, 400 watts ^^. Since it's two , 4Ohm speakers per channel in series, it'd be 2 ohms per channel I believe.
    2 Kicker Comp 10"
    Check it out?!
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    Oh and the wiring kit is rated at 200 watts.
    2 Kicker Comp 10"
    Check it out?!
    Nov 2003
    Tampa, FL
    refer to the other post "car stereo for idiots" or thereabouts to determine whether that's 400 watts RMS or whether that's 400 Peak watts. More that likely it's peak, and you're probaby fine with the 8 gauge wire.
    Next, are you sure it's series?? Series wiring of four 4 ohm speakers would actually mean that each channel sees 8ohms, and the acoustic output is lowered.
    If you're wiring two positives and two negatives together, it's parallel, and THEN it'll drop ohm levels to 2 and create increased acoustic output (read: louder). If you're crossing the 6x9s over (not too deep of a bass) so as not to draw too much current, let alone save the speakers from distortion, I believe you'll be fine with 8 gauge wire.
    Just my .02
    TaylorMade
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    "car stereo for idiots" pretty much said it all. LOL yea it's parallel. I'm going to try and return it, to get the 4 guage with distro block, so I don't have to run a n extra wire for my computer.
    2 Kicker Comp 10"
    Check it out?!
    Nov 2003
    Tampa, FL
    right on, that's the safe bet.
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    Yea, if they'll take it back... I opened it. Ebay anyone? Actually if I exchange, It shouldn't be a problem. Thanks for all the feedback/help. I shoud've paid more attention... DOH.
    2 Kicker Comp 10"
    Check it out?!
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    Update.
    Grr. Marketing! I returned my Monster for a better one. And found that they had one that was rated at 1000 watts, but it was still 8 guage!!! Bought it. Oh well, saved five bucks, and if this one breaks, I'll still be covered by warranty cuz I'm not overloading it, according to the box.
    Today I learned about marketing. You can buy a 1000 watt monster for $120 or pay $30 like mine. Granted I know monter kicks it's butt, but if this works... why pay more?
    2 Kicker Comp 10"
    Check it out?!
    Jul 2003
    So. Cal.
    wal mart sells decent wiring kits cheep.
  1. PC Motherboard to 1 amp or 2?
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  2. People with NO HeadUnit, Recommand AMP!!
    By camsgs3 in forum Newbie
    Last Post: 07-26-2004, 07:38 PM
  3. Audi S4 and BOSE wiring
    By prophet in forum Car Audio
    Last Post: 04-17-2004, 06:16 PM
  4. amp +smoke = bad USUALLY
    By pcman_cortina in forum Off Topic
    Last Post: 07-09-2002, 04:20 AM
  5. Specific wiring schematic 4 Optrex DMC40457?
    By sooty in forum LCD/Display
    Last Post: 07-17-2001, 03:11 AM
