My Cubid case was a tight fit when I got it, then I stuffed an Opus 150 watt in there and relocated the HD, theres no way I am fitting anything else in there.
Depending on your space you can just slap in a 2 card riseron an ITX board anf get 2 PCI cards not just one. So no you don't loose the single PCI slot. Just put a riser in... sound plus 802.11x PCI card (I don't like PC Cards) or a PCI AM/FM tuner card if you have no headunit... all just depends on your space.Originally Posted by ELEmental59437
@phatbimmer
Yes there is a button to switch beetween digital and analog. You can use the prologic with analog to distribute the sound to each chanel
Space is usually a comodity in the carputer world i.e. i have my carputer in my glovebox so there is no way a can fit a riser card.
@corruption
You certianly lost me. What device exactly has the Digital DIN type of connector and where are you connecting it?
I was thinking of using the Midiland ADS4000 to decode spdif into six channels. Any thoughts?
I dont know if this is related to phatbimmer's question...
Does the external dsp just decode 5.1 signals or does it also convert 2 channel sources into 5.1 kinda like prologic does.
Meaning: What if you just want 2 channel normal stereo and only want 5.1 when playing dvds. Since it's only stereo, will it come out stereo, or will it be turned into "fake surround".
thanks
@l4tran
Never heard of it. Are you sure that is correct name. I did a search and couldn't find anything on it
@mbaratta
The DSP decodes both Dolby digital (5.1 codec) DTS (5.1 codec) Linear PCM (stereo codec...this is what mp3's get interpreted as) and Pro Logic which is more of an filter that takes analog and creates a "fake" surround
Also for those who are interested... One snag that I have stumbled upon is the use of the MIC and Line in with S/PDIF out.
I think this might be a driver issue because a member here that has the EPIA M10000 has the 'line in' input coming out the spdif on his HTPC.
I have tried a series of drivers listed on the viarena website and still cant get the line in to play out the S/PDIF
There are two solutions
1. run an anolog line from the PC line out to the DSP and settle for analog... or
2. Find the correct driver that will successfully acomplish this.
As of now i have already ran a Phoenix Gold RCA cable to the DSP (i havn't tested it yet though) I will keep this thread updated
Yes the name is correct. here is the link. you have to cut and paste it.Originally Posted by antimatter
http://midiland.com/proddetail.asp?l...r=60&category=
My ADS3000 arrived yesturday, bought it for $50. I'll will test it out and see how it perform.
What about this one: Creative Decoder DDTS-100 , looks good for $120 .. newegg
6.1 channel audio processor supporting Dolby® Digital EX and DTS®-ES, Dolby Pro Logic II and DTS Neo:6,
