Results 1 to 7 of 7
Thread: Preamp?
    PJR
    PJR is offline
    Newbie PJR's Avatar
    Mar 2004
    S. Florida
    Preamp?
    Is a pre amp needed to hook the computers audio to an amplifier? I currently have the usb (creative mp3 sound card) outputing directly into a 4 channel 400w amp. The problem is that the sound kicks in and out and I know all my connections are correct on the amp and it is brand new. Any suggestions?
    Mar 2004
    Los Angles
    well if your amp is designed for a 4 volt input you might need it because your PC sound card is only 2 volts if it doesn't happen when the pc's volume is all the way up then I would say that is the problem you need a preamp line driver
    what brand and model amp u got?
    PJR
    PJR is offline
    Newbie PJR's Avatar
    Mar 2004
    S. Florida
    Nevermind it was all due to a faulty remote. Amp is up and running now. Thanks
    Maximum Bitrate SjLucky's Avatar
    Jul 2003
    Hattiesburg, Mississippi
    hey it might be a faulty remote....
    Just thought I would let you know
    Quote Originally Posted by menudude View Post
    thank you all for your help minus the useless post by sjlucky...
    Jan 2004
    but what if you pc is 2v and the carhead unit inputs are 4v what should someone do about ths as i think i might have that problem as when i play a cd in the headunitit ismuch louder than the pc
    Maximum Bitrate SAScooby's Avatar
    Feb 2004
    Johannesburg, South Africa
    the solution is at www.davidnavone.com
    look for line drivers, they have some that are adjustable up to 10v output, used by the sound quality and sound pressure wizards, about 165 or 145 usd a pair, if going for 5.1 sound you will need 3
    Once my screen is installed and i can test the install I may have the same prob as you and need to get these, email david at the site, he will help you out 100%
    Cheers
    Jan 2004
    this might sound really dumb but my home pc is 2v and connects to a what must be a 4v hifi ok my home pc also has 2 speaker outs on it one at the fron and one at the back so if i get a two, two to one rca pulgs and connect them up right wouldi then have a 4 volt system or is this just me being very very dumb
  1. Replies: 0
    Last Post: 04-04-2004, 01:15 PM
  2. FS: NEW Clarion Preamp equalizer EQS560. Trades welcome!
    By guitar333 in forum Classified Archive
    Last Post: 12-02-2003, 10:16 AM
  3. Special audio preamp circuit
    By claylong in forum General Hardware Discussion
    Last Post: 01-14-2003, 05:19 PM
  4. Audio and amps - building a preamp.
    By claylong in forum Power Supplies
    Last Post: 03-26-2002, 09:45 AM
  5. anyone familiar with clarion pro heads and reverse wiring the preamp outs?
    By RoGuEBiTcH in forum General Hardware Discussion
    Last Post: 08-11-1999, 12:03 AM
