Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: My Electrical Wiring Diagram
  1. #21
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    i have 4AWG + with 8AWG - and haven't had any problems...would I get more power to run both 4AWG?
    The wiring kit I bought that had a bunch of wire that I might need suggested the 8 for grnd and 4 for red.
  2. #22
    Feb 2004
    Quote Originally Posted by hifiguy
    sweet diagram [iG]! i was actually about to start my own diagram and did a search and found yours! i'll also be using JL amps, a 500/1 and a 450/4 on a 2004 m3, once it arrives anyhow.
    how are you going to turn on the amps, using a switch or a lead from your headunit? i'm going to skip the headunit so im hoping i can switch on/off both amps via a single +12V switch, if not then two switches. do you know if this is possible?
    Don't quote me on this, better checking out an audio board as someone once told me the output on the back of the head unit for the power on lead is only a few volts, not 12. Check it out just incase though.
  3. #23
    Oct 2003
    Toronto, Canada
    Quote Originally Posted by davcd3
    Interesting. I will, though i dont see why that would be the case. If anything i'll just use my carputter on/off as a remote on/off
    More power? Only if you put TYPE R stickers on the cable, the electrons flow 4x times as fast.
    No you wouldn't. The point of getting 'bigger' cable is that every AWG has a max rated amp's it can take, after that - theoretically - you can run into problems such as the cable melting etc. So, if you're running insane amounts of power to your amps/subs etc. You need a bigger cable... Otherwise, since you mentioned everything is working fine, leave it like that.
    As pokey said though, it is a better practice to run the same ground awg and power. Less resistance there is, less noise there will be in your system.
    VIA Epia II
    256MB 266DDR Ram
    90GB Wester Digital
    Bluetooth/Deluo GPS
    Lilliput 7" Touchscreen
    Mazda 6 Carputter > Click Me!
  4. #24
    FLAC mbkowns's Avatar
    Mar 2004
    SOCAL
    a switch will be fine for 12v.....
    2005 Ford Mustang GT <- - - UPDATED PICTURES
    2003 KAWASAKI Z1000 - CUSTOM MODZ
    MBK (AIM = IllMBKllI)
  1. emerson 8100 wiring diagram???
    By etrik in forum General Hardware Discussion
    Last Post: 02-11-2007, 12:40 PM
  2. Wiring Diagram
    By Dave in forum Newbie
    Last Post: 11-03-2003, 11:31 AM
  3. reading electrical diagram?
    By etrik in forum LCD/Display
    Last Post: 03-24-2002, 02:57 PM
  4. datalux 4x20 red lcd wiring diagram?
    Last Post: 12-07-2001, 03:35 PM
  5. Specific wiring schematic 4 Optrex DMC40457?
    By sooty in forum LCD/Display
    Last Post: 07-17-2001, 02:11 AM
