Page 2 of 7 FirstFirst 1234567 LastLast
Results 11 to 20 of 69
Thread: 4 to 6 channel amp recomendation for 5.1 DD
  1. #11
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Thanks, Just curious cause i didn't see it listed and I am not aware of Soundstream
  2. #12
    Mar 2002
    Really good amps IMHO i have 2 MMATS pro series hooked up running at a 1Ohm load. The amp (Soundstream Reference Class A 5.0) has never had any problems, although it does tend to run a little hot. (I've had the amp for about 4 years now and it has blown several sets of subs, however these MMATS seem to keep up well)
  3. #13
    Dec 2003
    The classes are what type of amplification it is.
    D is digital amplication which means 100% of the signle is amplified.
    Class A amplifies 100% with no distortion
    anc Class B amplifies 50% with distortion.
  4. #14
    Jan 2004
    California
    Thanks Raged,
    The classes are important. Class D is good subs becasue the frequency that the noise is comonly found is usually filtered out by low pass crossover. Most A amps are really A/B combos.
    I don't want a D. I want an A/B
    I did order the soundtreem
  5. #15
    Maximum Bitrate falconey's Avatar
    Feb 2004
    Atlanta
    Quote Originally Posted by antimatter
    Thanks Raged,
    Good deal, hope it works out for ya!
  6. #16
    Jan 2004
    California
    When I get the amp i will post a review
  7. #17
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    I have heard that the new soundstream amps arn't as good as the old ones. It will be good to read your review as I am looking at buying one
  8. #18
    Constant Bitrate SinnerG's Avatar
    May 2003
    Long Beach
    I've been doing some research on an "all in one" amp to do 5.1. Only three have made the cut....
    1. Audiobahn A5100T
    Features
    4-Ohm RMS Power Output
    Front: 125W x 2
    Center: 75W x 1
    Rear: 75W x 2
    Subwoofer: 300W x 1
    2-Ohm RMS Power Output
    Front: 200W x 2
    Center: 130W x 1
    Rear: 130W x 2
    Subwoofer: 500W x 1
    Class A/B MOSFET Circuitry
    PWM MOSFET Power Supply
    Double Sided Glass Epoxy Circuit Board
    6-Channel RCA Input
    Variable 18dB High / Low-Pass Crossovers
    Variable Subsonic Filter
    3-Way Protection Circuitry
    Cobalt Blue Illumination
    Blue LED Voltage and Status LEDs
    High Gloss Chrome-Plated Finish
    Nickel-Plated Block Terminals
    Fan Cooled with Flame Fan Grille
    2. Soundstream D'Artagnan
    • RUBI™ (Rapid-Use Branched Impulse) Proprietary power supply topology
    • STACT™ (STabilized Apex Current Topology) Reduces power supply stress by 50%
    • Auto High Current™ Matches the amplifier for virtually every load application
    • Chassisink™ Transistors are located between circuit board and heatsink for optimal heat dissipation
    • Variable Input level controls for exact input match to amplifier
    • Continuously variable 24dB low-pass crossover (40Hz to 220Hz)
    • Continuously variable 12dB high-pass crossover (50Hz to 200Hz)
    • Hawkins Bass Control™ Proprietary bass equalization topology
    • Harmonic Bass Alignment™ Produces tighter and more accurate bass reproduction
    • Continuously variable subsonic filter (13Hz to 30Hz)
    • Trident™ amplifier protection topology
    • IDI™ (Intelligent Distress Indicator) gives visual conformation of protection status
    • Balanced Line inputs for the highest level of noise rejection • Platinum RCA input and output
    • Platinum 4 gauge power inputs
    • 10Hz – 30 kHz frequency response
    • >100dB S/N ratio• 0.02% THD• 6 Channels
    • RMS @ 4 ohm 65 x 5 + 200 x 1
    • RMS @ 2 ohm 100 x 5 + 400 x 1
    • RMS @ 1 ohm 500 x 1 (sub only)
    • Dimensions: 19” x 11.5” x 2.25”
    3. Soundstream DaVinci
    SPECS
    NUMBER OF CHANNELS 7
    OUTPUT POWER (WATTS): RMS @ 4 Ohms 50 x 4,+100 x 2,+200 x 1
    RMS @ 2 Ohms 100 x 4,+200 x 2,+ 400 x 1
    RMS @ 1 Ohms 500 x 1 (subwoofer channel only)
    T.H.D.: <0.02%
    FREQUENCY RESPONSE: Channels 1-6 15 - 50k
    Channel 7 25 - 2k
    SIGNAL TO NOISE RATIO: >100dB
    CHANNEL SEPERATION: >60dB
    DAMPING FACTOR: >200
    INPUT SENSITIVITY: 500mV - 5.0V
    CROSOVER SLOPES: High-pass/Band-Pass 12dB
    Low-Pass 24dB
    CROSSOVER FREQUENCIES (HZ):* High-pass/Band-Pass 50 - 4k
    Low-Pass 200-800
    REAR CHANNEL DE-EMPHASIS: 6dB
    DIMENSIONS (INCHES): 19 x 14 x 5.5
    IMHO, the Audiobahn A5100t has the best bang for your buck (better specs than the D'Artagnan), but the DaVinci is my dream setup.
  9. #19
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    Quote Originally Posted by Raged
    "The “D” in class-D is sometimes said to standfor “digital.” This is not correct because the operation of the class-D amplifier is based on analogprinciples. There is no digital coding of the signal."
    http://users.ece.gatech.edu/~mleach/...01/ClassD2.pdf
    class A has good sound quality.
    class B is efficient
    class AB is efficient and sounds good.
    do you really have a center speaker in your car?
    i'd go with a 5 channel amp and a mono amp for the subs instead of just one amp.
    rebuilding carpc... kinda..
  10. #20
    Maximum Bitrate jusatry's Avatar
    Nov 2003
    Quote Originally Posted by fantomas
    Can you either
    a)translate that article into english
    or
    b)explain what class D does mean?
    I always thought the classes had to do with efficiency rating for power, D being the best.
  1. del
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  2. People with NO HeadUnit, Recommand AMP!!
    By camsgs3 in forum Newbie
    Last Post: 07-26-2004, 07:38 PM
  3. 2 channel amp to 4 channel SPs
    By zvi in forum General Hardware Discussion
    Last Post: 02-17-2004, 11:46 AM
  4. Replies: 1
    Last Post: 11-17-2003, 04:21 PM
  5. Looking for opinions on Alpine MRV-F450 5 channel amp
    By ShinkunoNamida in forum General MP3Car Discussion
    Last Post: 09-20-2002, 06:57 PM
