Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 69
Thread: 4 to 6 channel amp recomendation for 5.1 DD
  1. #21
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    I should get my D'artigan amp in tomorrow (well i guess it is today) anyways i will be installing it this afternoon. Depending on if i hit any snags or not i will post a review tonight or sunday.
    I was reading the PDF online and I got excited. This AMP should handle all of my needs but only time will tell
    @sinnergy. I did look at that audiobahn but (unexplainably) didn't have a good feeling about it.
    @jusatry I was wondering what the classes were all about recently. I found a good explaination on crutchfields website. If you are curious do a google search.
  2. #22
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    crutchfield's site...a much better explaination of the classes.
    http://www.crutchfieldadvisor.com/S-..._glossary.html
    that link in my previous post..i was just referring to the first page on how class D does not neccessarily mean digital. i did some more researching and i guess there are two catagories of class D amps and one is digital (or mostly digital).
    rebuilding carpc... kinda..
  3. #23
    Mar 2002
    Ya, I also noticed the audibahn and it seems nice according to the ratings, however, in my experience soundstream usually under rates its amps (meaning the specs they give are well under the actual power output). Also due to my sub configuration, I need a sub channel with the lowest stable configuration available ...
  4. #24
    Maximum Bitrate falconey's Avatar
    Feb 2004
    Atlanta
    800-2500 bucks for amps...my goodness I feel like the pauper surrounding by princes that are soon to be kings. lol
  5. #25
    Jan 2004
    California
    I have installed the D'artigan 5.1 amp.
    I have to ay that I am very pleased. It has accomidated my systems needs and then some.
    It is a very high quality amp. I would recomend it to anyone who desires 5.1 surround sound amplification in a car environment.
    If anyone has specific questions about it I can try my best to answer them.
    One question I have is How do I use the BIO Port to double the wattage on the subwoofer chanel?
  6. #26
    Mar 2002
    its used to bridge multiple amplifiers. i.e. you need another Soundstream amp:
    "The BIO (Bridging In and Out) Portô allows customers to buy an amplifier, use it on their subwoofers, and then later double its power output. In the new D'Artagnan 5.1 amplifier, BIO Port circuitry allows users to add a second amplifier, namely the new Rubicon501/, to drive a single subwoofer channel with double the power! Since these amps have true mono channels it is now possible to bridge two separate amplifiers into one load. By inverting one of the amplifiers and synchronizing their supplies, the amplifiers can double their power into one channel, for up to 1000 watts at 2 ohms mono. Furthermore, the variable controls of the first amplifier (gain, Hawkins Bass Control, and crossover functions) will control both units."
    LINK
  7. #27
    Jan 2004
    California
    Thanks for the quick reply.
    Thanks for the link. It says which am needs to be used with the D'Artigan (Rubicon501/ amp) but I was curious on how to wire it.
    It is nice to have the expandability in case i want to push some more heavy duty woofers. Right now i am pushing 1 10" in a sealed enclosure but at 400w rms and it works fine. I am sure i could push a 12" at that power but if i wanted to do two subs i would definitly need to do the BIO port thing. I am kinda unclear on the how to wire them though
  8. #28
    Mar 2002
    From the 501 owners manual:
    "B/O Port Bridging Option
    The Rubicon5Ol/ amplifier has the ability to be bridged to another identical amplifier for double the output by using the BIO Port. When this feature is used, the master amplifierís level and crossover switches affect both amplifiers the slave amplifierís controls are totally bypassed). By switching the phase switch to 180 on the slave amplifier and connecting a RCA cable from the 501/ OUT on the master amplifier to the 501/IN on the slave amplifier both amplifiers are synchronized. Then connect a positive speaker cable to the master amplifierís positive speaker terminal and the other speaker cable to the slave amplifierís positive terminal. Finally connect the speaker wires to a single load no less than 2 ohms. This will supply twice the power of a single amplifier."
    Doesn't seem clear to me, but then again I'm more of a visual person.
    Good luck and thanks for the review!
  9. #29
    Constant Bitrate coachreed's Avatar
    May 2004
    Lee's Summit, MO, USA
    Quote Originally Posted by dominic
    im sorry but i have to post this even though it will cost a fortune, and ive never seen them for sale!!
    its a 6 channel 5x50W + 1x250W digital amp, i.e. it has an spdif in!
    http://www.tbk.co.kr/eng/products_so...um=3&idorder=0
    I like the looks of this amp and its specs... unfortunately, I couldn't find any other info than what was on that page. Where can I find this amp and how much does it go for? I have a bunch of amps sitting here new in the box to build my system... total of four amps to run 6.1 but if I had an amp like that... I would cut things down to simplify things. Lemme know. TTYL!
    Coach... I mean Randy (I often forget who I really am)
    Undergoing LS1 Conversion as we speak!
    Click Image to Visit My Website!
  10. #30
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    http://www.tbk.co.kr/eng/products_s...num=3&idorder=0
    did anyone ever actually get a price or more infromation on these amps? I might just send them an email.
  1. del
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  2. People with NO HeadUnit, Recommand AMP!!
    By camsgs3 in forum Newbie
    Last Post: 07-26-2004, 07:38 PM
  3. 2 channel amp to 4 channel SPs
    By zvi in forum General Hardware Discussion
    Last Post: 02-17-2004, 11:46 AM
  4. Replies: 1
    Last Post: 11-17-2003, 04:21 PM
  5. Looking for opinions on Alpine MRV-F450 5 channel amp
    By ShinkunoNamida in forum General MP3Car Discussion
    Last Post: 09-20-2002, 06:57 PM
