Results 1 to 10 of 11
Thread: Aluminium foil help reduce engine noise?
    Constant Bitrate JayKaye's Avatar
    Jan 2004
    Sydney, Australia
    Hi all,
    I recently found the source of my engine noise. It is coming from the power cables and PC PSU which is around 10 - 15cm away from the 3 RCA pairs going into my equaliser. My question is, would wrapping the RCA's in aluminium
    Cen Cal
    Maybe, but I doubt it. I would instead find an alternate route for the cables. It can't hurt the try the foil method, though.
    Maximum Bitrate falconey's Avatar
    Feb 2004
    Atlanta
    I don't know something makes me think that would help it pick up more noise. I would re-route the wiring or if that isn't try something like duct tape or something. Better yet if you don't have high quality cables and you can't re-route the wiring get some shielded cables.
    Feb 2004
    Atlanta
    Let us know if the foil works if you try it. Thanks
    Sep 2003
    Virginia
    it it doesn't work at first, try gounding the foil somehow.
    May 2004
    Curacao, Netherlands Antilles
    if the foil helps(at least a little) , then a possible fix would be to buy shielded rca cables but it could be more work (cost more too) then just to run them somewhere where they are far away from the power cables
    Cen Cal
    Did you try grounding it like mhorton said? If you search, there are also many other ways to reduce noise.
    Dec 2002
    Chico, Ca
    Hmm, physics course should help you on that one, your looking essentially for a faraday cage. I don't think foil's going to be your answer though. Shielded cables will probably be your best bet, otherwise we would all be running out and bying foil instead of exspensive cables.
    Jan 2004
    Sydney, Australia
    I havnt tried this approach yet guys. I probably wont bother either as my RCA's are already shielded and im 99% sure the noise I am picking up is through my dodgy Equaliser (one of those small half-DIN ones).
    My power cables are running along the far left of my car and the RCAs/speaker cables are running along the far right. That isnt an issue, however I found arouind 70% of engine noise was cut out when I cable tied (zip tie) the power cables behind the dash further away from the equaliser and grounded everything at a point which didnt pass the equaliser.
    Mar 2004
    Inverter?
    Hi,
    If you're using an inverter to power the system and you're running it off the accessory line, can I recommend that you run dedicated power cables to it direct from the car battery. I have done this and I get no noise even without grounding the pc, inverter, psu or anything.
    Just in case this is the situation,
    Web
  1. ARGH! Engine noise!!
    By JayKaye in forum Car Audio
    Last Post: 06-01-2008, 05:08 AM
  2. Replies: 86
    Last Post: 04-04-2005, 03:57 PM
  3. Damn Noise
    By Freeman in forum General Hardware Discussion
    Last Post: 03-20-2004, 12:37 AM
  4. Replies: 3
    Last Post: 03-25-2003, 05:35 AM
  5. dc-dc and engine noise
    By Harvester in forum General Hardware Discussion
    Last Post: 11-05-1999, 05:31 PM
